Code 92
Old Oct 15, 2002 | 04:21 PM
spoon_ek9's Avatar
Default Code 92
what i have to do to shut this code off?
Old Oct 15, 2002 | 05:21 PM
satan_srv's Avatar
Default Re: Code 92 (spoon_ek9)
Welll...from a Prelude P13/P5P
92 - Evaporative Emission Control System
Detection Item
- Insufficient Purge Flow
- Purge Flow Switch Malfunction
Probable Cause:
EVAP Purge Control Solenoid Valve
EVAP Purge Control Solenoid Valve Circuit
EVAP Purge Flow Switch
EVAP Purge Flow Switch Circuit
Throttle Body (Purge Port)
Tubing
Vacuum connections
ECM
What ECU what engine?
Old Oct 15, 2002 | 07:31 PM
spoon_ek9's Avatar
Default Re: Code 92 (satan_srv)
i use JDM ECU before but for smog purpose, i switch back to gsr ecu, and it didnt get that code first, but after couple days it came up. whats wrong with my purge valve, is that something wrong with my canister??
thank
Old Oct 15, 2002 | 08:23 PM
satan_srv's Avatar
Kay that's not right....the GS-R ECU does not have pinouts for EVAP stuff cause the B18C1 doesn't have it.....it must be a different code
edit: I think I'm losing it...http://www.c-speedracing.com/faq.html it says it is a code...check your vacuum lines to the EVAP canister
[Modified by satan_srv, 12:50 AM 10/16/2002]
Old Oct 15, 2002 | 10:14 PM
spoon_ek9's Avatar
thats the problem, i got the cansiter but i dunno if i run it right.............any pic to show how it run?
BadAndy
Feb 18, 2004 03:54 PM
blackcruzan
Dec 10, 2003 09:30 AM
speedymon
Jul 16, 2002 08:39 PM
