Does compression ratio and/or cams affect compression test numbers?
Old Oct 18, 2002 | 11:06 PM
ingrate's Avatar
25 Year Member
Default Does compression ratio and/or cams affect compression test numbers?
i was just wondering. thanks.
Old Oct 19, 2002 | 12:01 AM
miller's Avatar
Default Re: Does compression ratio and/or cams affect compression test numbers? (In7egrity)
compression ratio does,but the cam size dosent!! if you would like a detailed answer just give me a shout....
Old Oct 19, 2002 | 12:06 AM
texan's Avatar
yes, basically anything that significantly affects cylinder filling can affect compression test numbers. Though the slow speed of the engine cranking will show very litttle effect from most cams (they'd have to be gigantic), varying static compression ratio will show a marked change in peak numbers.
[Modified by texan, 1:07 AM 10/19/2002]
Old Oct 19, 2002 | 09:34 PM
ingrate's Avatar
25 Year Member
Default Re: Does compression ratio and/or cams affect compression test numbers? (texan)
so the cams won't affect static compression, but will they noticeably affect the compression when the engine is actually running?
Old Oct 19, 2002 | 09:47 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Does compression ratio and/or cams affect compression test numbers? (vtecdoc)
cam size AND cam timng will effect cranking compression numbers. Just changing the cam timing can effect the cranking compression numbers by over 20%.
Numbers for thinking
D16 with stock cam at zero, 200 psi across the board
same setup with cam at 2 degress retard, 180 psi
4 degrees retard and I got 160-165 psi cranking compression numbers.
Old Oct 20, 2002 | 12:22 PM
AzG35's Avatar
Default Re: Does compression ratio and/or cams affect compression test numbers? (Mista Bone)
Yeah, I'm thinking the same thing as Mista Bone. When I did my compression test the first time, my cams were set at +3 degrees (intake) and the numbers were close to 230psi. Now with them set at +1 degree (intake) the numbers are closer to 220psi.
Old Oct 20, 2002 | 02:02 PM
budlight's Avatar
Default Re: Does compression ratio and/or cams affect compression test numbers? (AzSi22)
is the stock setting 0 and 0
Old Oct 20, 2002 | 03:16 PM
3rdGteg's Avatar
Default Re: Does compression ratio and/or cams affect compression test numbers? (budlight)
Yes, for cam timing.
integra123
May 10, 2006 01:05 PM
dohcter g
May 24, 2005 01:53 PM
.nate
May 6, 2005 06:26 AM
Dan GSR
Aug 27, 2004 07:15 PM
evo
Jun 12, 2002 03:45 PM
