Wiring OB1 car to OBD2 engine harness
Old Oct 18, 2002 | 11:09 PM
DrkGreenAccord's Avatar
Default Wiring OB1 car to OBD2 engine harness
As the topic says, what do I do. I have a 95 accord EX manual mounting up to a 98 prelude. I will be using my tranny from the accord and the accord ECU POA, but that shouldn't matter, since the pinouts should be the same on all OBD1 ECU's.
The thing is, my ecu harness on the accord has 3 gray connectors, while the prelude engine harness has 4..... why is there an extra plug?! I know the prelude has more sensors being it OBD2.....
On the engine, do I use my accord harness? If so, what about the extra sensors that the harness will not mount up to? Please help!!
Old Oct 19, 2002 | 06:27 AM
Default Re: Wiring OB1 car to OBD2 engine harness (DrkGreenAccord)
Bumping this, please respond..
Old Oct 19, 2002 | 11:42 AM
Katman's Avatar
im sorry...im just a little confused here.
You have a 95 EX accord that you're dropping an '98 H22 engine into ? correct?
if so, (for example) this should be on the same scale as putting an OBD2 B-series engine into a 92-95 civic. You would just use the OBD2 H22 engine harness, plug in all necessary plugs, and leave the extra OBD2 plugs unplugged/dormant (hangin there); and since you'd be using an OBD1 ecu, it will not look for the extra OBD2 sensors.
HTH if any...
[Modified by Katman, 12:44 PM 10/19/2002]
Old Oct 19, 2002 | 04:54 PM
Default Re: Wiring OB1 car to OBD2 engine harness (Katman)
Thanks man, gonna try it and see what happens.... If you think of anything I need to do, please post it.
Would it matter if the prelude tranny was SS? So the 2 blue connectors would be hanging there also?
Also, thanks for replying... I post this on various boards, and they had no clue....
Old Oct 21, 2002 | 12:40 PM
Katman's Avatar
I'm not too sure about the auto tranny's ....never dealt with an install of one.
SiRCD5
Jul 14, 2014 05:35 AM
aasaa666
Mar 6, 2008 09:26 PM
97LXF20B
Oct 9, 2007 09:49 AM
AVcTcEoCrd
Sep 26, 2004 07:35 PM
xtrmspeed
Sep 5, 2003 09:26 PM
