CEL From Test Pipe
Old Oct 15, 2002 | 06:42 AM
integranator's Avatar
Default CEL From Test Pipe
I think I how to get rid of that pesky CEL from having a test pipe, and I want to see if you believe it would work. I say, put a resistor inline with the 2nd O2 sensor--Since the ecu checks for different voltage between the 1st and 2nd sensor, so if you vary the voltage between the two, it will send this signal to the ecu that the cat is working. Any thoughts? Or am i really off and this has been done?
Old Oct 15, 2002 | 07:07 AM
lightning's Avatar
Default Re: CEL From Test Pipe (integranator)
It's not the voltage, it's the wavelength. If you look at the signal on a scope, the amplitude (voltage) is the same but the wavelength is different. It is shorter on the first O2 than it is on the 2nd O2.
kevinm1981
Oct 7, 2009 02:58 PM
01DC4
Honda S2000
Feb 27, 2008 12:57 PM
TURBOED-TEG
Jun 24, 2002 09:19 AM
comptechgsr2000
May 9, 2002 07:36 PM
Qwikrex
Apr 11, 2002 05:17 PM
