JDM ITR cluster question
Old Oct 19, 2002 | 03:32 PM
SMZ GSR's Avatar
Default JDM ITR cluster question
Hey guys, i drive a 98 GSR and just bought a JDM ITR cluster. I believe the cluster is from a 2000 or 2001 because it has the little key icon and only had 16k KM. Well my friend and i installed it today and both the temp and fuel gauges wouldn't work. the temp stayed at C and the fuel gauge went from me having a 1/4 of a tank to having a full tank. Then we tested the cruise control since the light on that wouldn't go off either. once cruise was engaged the Maint Req light came on.
My question is, could it be messed up because of the different year or is it busted? The guy i bought it from says he has a 94 and says it worked fine.
If it's because of the year, is there anyone in So Cal who would help me by trying it out on their 00/01 ITR. Thanks ahead of time.
Old Oct 19, 2002 | 06:11 PM
mugenracer's Avatar
Default Re: JDM ITR cluster question (SMZ812)
remove it again and compare the back circuitry to your own, you will most likely find that its different. there are several threads here from members who had the smae problem, i think you are going to have to remove the plastic with the circuitry from your original and put it onto the JDM cluster. I bought a jdm ITR cluster a while back, i was looking for one for ages, but all the ones on ebay had the warning lights in different places (the abs light was usually on the top, its on the bottom on mine, plus the seat belt light and door open lite were in different places too) i finally found one that was exactly the same as mine and bought it, plugged it in and everything worked 100%
saerock
Oct 8, 2006 10:26 AM
kenji
Aug 11, 2005 11:09 AM
SMZ GSR
May 10, 2004 02:57 AM
01DC-2
Apr 1, 2004 09:43 AM
SMZ GSR
Oct 20, 2002 02:21 PM
