Differences in Trannys
Old Oct 16, 2002 | 04:32 PM
95c1v1cs1's Avatar
Default Differences in Trannys
How much different is the LS tranny than the GSR tranny (both 94-01). I am going to boost and i know the Ls is better for that but how much better will it be. The thing that i notice most is that the Final drives. 4.26 to 4.40. 1st and 2nd gear ratios are the same, which i would think are most cruical. But will that final drive come into play with that as well?
Old Oct 16, 2002 | 06:49 PM
95c1v1cs1's Avatar
Default Re: Differences in Trannys (95c1v1cs1)
Anyone, How much more aggresive is the GSR than the LS???
Old Oct 16, 2002 | 06:57 PM
95c1v1cs1's Avatar
FYI Its gonna be on a 14 lbs of boost.
Old Oct 16, 2002 | 07:42 PM
95c1v1cs1's Avatar
Alright, disregred what i have said above. what tranny do you think i should go with for boosting a car? The Ls tranny or the gsr tranny??? I am putting a new diff(Quaife) in it either way that i go.
Old Oct 16, 2002 | 09:02 PM
kinesistech's Avatar
Sorry no one cares.
Use the ls tranny. Turbo cars are fast anyway, you may as well have to top end too.
Old Oct 17, 2002 | 05:10 AM
95c1v1cs1's Avatar
Default Re: Differences in Trannys (kinesistech)
I've heard ls tranny synco's and diff are weak. Can you put the ls final drive in a gsr. I heard that the gsr tranny's are better built. More versitile.
[Modified by 95c1v1cs1, 2:11 PM 10/17/2002]
Old Oct 17, 2002 | 06:44 AM
Copy Cat's Avatar
I really don't know much about the gsr tranny, but all i know is that people in my area us an LS tranny because the gears are taller. By the gears being taller you stay in boost longer.
Old Oct 17, 2002 | 11:30 AM
vbphreak's Avatar
Default Re: Differences in Trannys (Ridinlowcivic)
go with the ITR. LSD is a plus especially if you're on boost.
tegasaurus
Feb 5, 2007 07:29 PM
whiteyGSR
May 20, 2004 06:51 PM
crazed_crx
Dec 4, 2003 07:28 AM
Se-rv-Tak
Sep 5, 2003 01:07 PM
H22CIVIC
Oct 21, 2001 11:58 AM
