Speedometer works sometimes??????
Old Oct 18, 2002 | 08:17 AM
underpressure02's Avatar
Default Speedometer works sometimes??????
I have an LS tranny and the speedometer will work then it will just stop while I am driving. Then it will start working again any ideas? TIA
Old Oct 18, 2002 | 02:11 PM
Chiovnidca's Avatar
Default Re: Speedometer works sometimes?????? (underpressure (wtbimport))
What year and model?
Old Oct 18, 2002 | 02:18 PM
Default Re: Speedometer works sometimes?????? (Chiovnidca)
It is in a 92 civic hatch the motor is a 95 ls and the trans is a ls tranny.
Old Oct 18, 2002 | 03:42 PM
JetSI's Avatar
I have a 92 Prelude SI that did the same thing. It was the speed sensor
Old Oct 18, 2002 | 08:49 PM
ImportRacing's Avatar
Default Re: Speedometer works sometimes?????? (JetSI)
i had the same problem, mine was bad connection fromthe wire to the vss. take the vss and put it in a friends car to see if it works. If it does than you might have loose wires somewhere.
Old Oct 19, 2002 | 04:31 PM
94gsr's Avatar
Bad sensor, bad ground, or open in the signal wire.
Old Oct 19, 2002 | 05:53 PM
Default Re: Speedometer works sometimes?????? (94gsr)
Update on situation. I drove the car about 400 miles today. It will be working fine then just stop and then start working again. It does not do it when I hit a bump or anything like that. I will just be driving and it will go to zero then come back up to the correct speed? Don't know if this helps. I checked the connection to where it goes into the tranny and that seems fine.
Old Oct 19, 2002 | 07:18 PM
gregv's Avatar
sorry, but I am not familiar with the method of input to your speedo on this model.
If it is electronic, disregard this post. If it is cable, you may want to check the actual needle.
I had a speedo stop working, but I noticed that the odometer was still ticking. Turns out that
the needle seat had worn out, so I replaced it with a new needle; problem solved.
good luck.
Old Oct 19, 2002 | 08:28 PM
3rdGteg's Avatar
Default Re: Speedometer works sometimes?????? (gregv)
Vehicle Speed Sensor (VSS).
Old Oct 21, 2002 | 06:34 AM
Default Re: Speedometer works sometimes?????? (3rdGteg)
Is the Vehicle Speed Sensor (VSS). The part which is held down with 2 10mm bolts? And the plug goes into? Should I unbolt that and can it be cleaned or does it just need to be replaced?
PGHRich
11
Sep 10, 2010 05:18 PM
ULTRAdC2
Feb 1, 2007 05:27 PM
MikeNice
Nov 15, 2006 07:47 AM
f155mph
Jul 26, 2006 11:24 AM
hitekper4mance
Jan 7, 2003 04:40 PM
