Just a friendly reminder ....
Old Oct 16, 2002 | 03:59 PM
Tweakmeister's Avatar
Default Just a friendly reminder ....
to change that tranny oil! here is some Honda MTF after 30,000miles of love. I'll be changing it more frequently now, and will run a magnetic drain plug now too.
Old Oct 16, 2002 | 04:57 PM
MikeMAN's Avatar
Default Re: Just a friendly reminder .... (Tweakmeister)
wowza! how often should u change ur tranny oil??
Old Oct 16, 2002 | 05:04 PM
The_Oz's Avatar
Default Re: Just a friendly reminder .... (MikeMAN)
I change mine every 20000km.
Regards,
Oz
Old Oct 16, 2002 | 06:31 PM
keebler65's Avatar
Default Re: Just a friendly reminder .... (The_Oz)
someone on here recently mentioned every 10,000 miles. thats interesting - i've never heard of a magnetic drain plug. whats the scoop on that? like where do i get them/are they effective/any negatives?
thanks
Old Oct 16, 2002 | 06:59 PM
89 CRX SI's Avatar
Default Re: Just a friendly reminder .... (keebler65)
magnetic oil drain plug and tranny drain plug pick up all the metal schareds from lets say grinding it once somethime. this prevents it from going thru your tranny further damaging it. it also attaches to the plug so you can see that there are metal shavings in the tranny.
Old Oct 16, 2002 | 07:16 PM
GZERO's Avatar
Default Re: Just a friendly reminder .... (89 CRX SI)
i've heard of them, but the only ones i can seem to find are the Spoon, and i know there has to be something cheaper around, what do you guys use? or were do you get them?
Old Oct 16, 2002 | 07:19 PM
keebler65's Avatar
Default Re: Just a friendly reminder .... (GZERO)
i did a search on this and found autozone supposedly sells one for $3. i have yet to go there and look.
Old Oct 16, 2002 | 07:40 PM
GZERO's Avatar
tell me what you find out please, i'm really interested
Old Oct 16, 2002 | 08:52 PM
976's Avatar
976
New User
Fram I believe makes them. So Napa, Shucks, most automotive places should be able to order.
Wonder is OE honda makes em'?
I change fluid every 10-15K BTW.
Old Oct 17, 2002 | 04:44 AM
Mista Bone's Avatar
D Tranny Guru
ever see the STOCK magnets? The are pretty big.
BTW I can ALL fluids every spring. Part of the Autox ritual, but I haven't autoxed for 3 year now.
Old Oct 17, 2002 | 06:52 PM
Default Re: Just a friendly reminder .... (Mista Bone)
IPS Racing has them for $35...ah well. It's probably the only spoon thing I'll buy (okay forgot my ****)
I'll change mine every 10 or 15k now.
Old Oct 17, 2002 | 07:43 PM
straightline's Avatar
most parts stores have magnetic oil pan drain plugs for hondas for around $3 (do the same thing as a $45 spoon) but make sure you use a aluminum crush gasket on hondas, not the neprine that comes with the plug. A tranny magnetic plug really isn't nessesary considering, the tranny already has a pretty big magnet in it stock.
Old Oct 17, 2002 | 10:04 PM
irev210's Avatar
Default Re: Just a friendly reminder .... (straightline)
yah tranny has huge magnet... MTF fluid is 90wt gear oil, and a manual transmission, your not using the fluid to actually transfer toruqe in the torque converter like on an automatic (lots of energy, lots of heat) All it does is just rolls around... doesnt break down due to high heat or extreme working conditions.
But it definitly doesnt hurt to change it whenever u have time, but you just dont need to.
Old Oct 18, 2002 | 05:21 AM
ScrapinSi's Avatar
Default Re: Just a friendly reminder .... (sirhatchback)
ummm, honda trannies usually use 30 weight oil, not 90 weight gear oil... if i recall, when my clutch was done, mobil 1 synthetic 10w30 was used.
Old Oct 18, 2002 | 05:48 AM
jweller's Avatar
Default Re: Just a friendly reminder .... (ScrapinSi)
Not all honda trannies have a magnetic drain plug. mine isn't.
I'd stick with Honda MTF for fluid. I've only heard about 1000 different opinions on what else to use, but there is one I KNOW is correct - Honda MTF
Old Oct 18, 2002 | 09:30 AM
bruthaboost's Avatar
wow. I changed mine at 75000 and it was still golden brown.
Old Oct 18, 2002 | 02:16 PM
Quick 200k Mile Motor's Avatar
Default Re: Just a friendly reminder .... (bruthaboost)
in my opinion, anything JDM S1 or shorter ..you should change it every other engine oil change.
Rex89
16
Jan 2, 2007 06:24 PM
an2ny888
Oct 17, 2005 12:52 PM
Good ol' Screwtape
12
Dec 10, 2003 07:03 AM
King Tut33
May 14, 2003 04:31 PM
WickidSi
Mar 25, 2003 02:26 PM
