Fuel FIlter install
Old Oct 18, 2002 | 02:14 PM
LiZaRDz CiViC Si's Avatar
Default Fuel FIlter install
How do i get the bolt off the bottom of the fuel filter, The bolt is connected to a metal wire that i cant get off...Thanks
Old Mar 18, 2003 | 12:29 AM
Frankie324's Avatar
Default Re: Fuel FIlter install (LiZaRDz CiViC Si)
its a bitch.
it will never come off.
Old Mar 18, 2003 | 09:13 AM
Ponch's Avatar
Are you talking about the one that's welded on there??
Old Mar 18, 2003 | 01:34 PM
fathergoose's Avatar
Default Re: Fuel FIlter install (Ponch)
use a line wrench and brake that 14mm bolt loose. remove the 3 bolt that hold the fuel filter on the firewall then simply pull the fuel filter upwards the gaz line will slide out, you don't 'remove the bolt, just break it loose. Only the top 17mm bolt is removable.
Old Mar 19, 2003 | 09:17 AM
Audipwr1's Avatar
Default Re: Fuel FIlter install (fathergoose)
hehe i almost made that same mistake, trying to get that bottom one off.
best way is take top one off first (watch out for gas BTW even after i ran it till it stalled with pump off, a good amount still came out) then you can get the filter out, them things are nasty too
k3ntegra
Aug 28, 2014 05:50 PM
Nihsnek
17
Dec 30, 2011 02:40 PM
honcrx91si
Jul 4, 2007 01:47 PM
Archxor
Nov 7, 2006 04:36 PM
cvc323
Jun 29, 2003 11:09 PM
