valve cover won't come off
Old Oct 15, 2002 | 01:22 PM
wrXtian's Avatar
Default valve cover won't come off
well i was in my driveway today trying to get the valve cover off my car becuase i'm starting to pull the head off to put a new head gasket in.. there are 2 bolts that won't come off... i'm using my wrench and the nut will just spin in circles but won't come off or loosen.. it just continues to spin.. any suggestions on how to get this off before i push this car off a cliff...
Old Oct 15, 2002 | 01:29 PM
Nameless RB26's Avatar
Default Re: valve cover won't come off (xjdm94x)
Maybe your socket is too LARGE.
Old Oct 15, 2002 | 01:30 PM
tmg's Avatar
tmg
it seems that you have to pull and spin on the bolt at the same time. the threads aren't grabbing the metal to spin off.
Old Oct 15, 2002 | 01:49 PM
wrXtian's Avatar
Default Re: valve cover won't come off (Nameless)
i know the socket isn't 2 large because u can actually see the nut spinning along w/ the socket
Old Oct 15, 2002 | 02:28 PM
JBONES's Avatar
your bolt is stuck like chuck......try cutting the nut in half...with out cuting the valve cover
Old Oct 15, 2002 | 10:05 PM
wrXtian's Avatar
Default Re: valve cover won't come off (JBONES)
there is no other way other than cutting?? what can i use to cut this?
Old Oct 16, 2002 | 12:50 AM
NXSpoon's Avatar
Will a Dremel tool work?? I just used mine to cut through some metal bracing in my dash by the radio.
Old Oct 16, 2002 | 06:27 AM
rolow's Avatar
Default Re: valve cover won't come off (NXSpoon)
Is it a b-series valve cover?
If it is which two is it? The ones for the spark plug wire cover or the outside ones?
Old Oct 16, 2002 | 08:07 AM
wrXtian's Avatar
Default Re: valve cover won't come off (rolow)
it's a b series valve cover it's one of the outer ones... 2 of them to be exact
Old Oct 16, 2002 | 08:42 AM
rolow's Avatar
If you can see the nut spinning it sounds like the stud is stripped in the head.
Try this:
pull up on the valve cover while you try to loosen the nut
Old Oct 16, 2002 | 04:45 PM
wrXtian's Avatar
any of u guys know where i cna get the piece for the dremmel to cut the bolt? i don't really care about this head because i was taking it off to put in a new head gasket and throw a 94 ls head on it... i have a 90 integra.
Old Oct 17, 2002 | 12:27 AM
NXSpoon's Avatar
Usually Walmart, Home Depot, Sears... It is a cutting wheel, I believe w/ graphite reinforcement. It will be in an accessory pack, just gotta find the right one.
teamrpm2
Oct 31, 2009 12:13 PM
butter99
Jan 3, 2009 07:49 PM
Moto DC2
Dec 26, 2007 11:59 PM
B18C-YA!
Aug 1, 2006 11:18 AM
genetsang
Mar 25, 2004 02:40 PM
