ITR cams vs. CTR cams
Old Oct 19, 2002 | 09:15 AM
EJ8 Kenobi's Avatar
Default ITR cams vs. CTR cams
Which cams are more aggresive, I've heard that CTR cams are, and then last night I heard that ITR cams are more aggressive. How much of a difference is there between the two.
Old Oct 19, 2002 | 09:26 AM
VTEC-DA's Avatar
Default Re: ITR cams vs. CTR cams (FrankGSR)
Not sure about the USDM ITR cams but as far as teh JDM ones, the exhaust cam is the same on the ITR and CTR and the CTR intake cam is slightly more aggressive.
Old Oct 19, 2002 | 09:40 AM
Kataku2K3's Avatar
Default Re: ITR cams vs. CTR cams (turbo2dr)
I haven't mic'd them for sure but I've heard that 2000+ USDM ITR intake cams have a profile very similar to CTR.
Old Oct 19, 2002 | 10:54 AM
CHRIS 1.8's Avatar
Default Re: ITR cams vs. CTR cams (JDMspecEG6)
CTR cams all the way.
Old Oct 19, 2002 | 11:34 AM
Katman's Avatar
yes 00+ US ITR cams are exactly the same spec as CTR cams.
[Modified by Katman, 12:34 PM 10/19/2002]
Old Oct 19, 2002 | 02:33 PM
MikeSarr_GSR's Avatar
Default Re: ITR cams vs. CTR cams (Katman)
for the money, the CTR/ITR cams are the best way to go; especially if you have a stock rev limit.
Old Oct 19, 2002 | 02:45 PM
Doctor CorteZ's Avatar
Default Re: ITR cams vs. CTR cams (B16A1-EF8)
USDM 00-01 itr cams are the same.
Old Oct 21, 2002 | 02:48 PM
blackANESE's Avatar
Default Re: ITR cams vs. CTR cams (Doctor CorteZ)
Here are the specs.
Integra Type-R(Through 1999 Spec)
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
Old Oct 21, 2002 | 04:10 PM
eg6ajk's Avatar
Honda OEM and Aftermarket B-Series VTEC Cam Shaft
Chart:
Cams Measured at 1mm of lift:
Spec)
Skunk2 Stage 1
Int-252 dur. / 11.5mm lift
Exh-249 dur. / 10.8mm lift
JUN Type 1
Int-265 dur. / 10.9mm lift
Exh-268 dur. / 10.0mm lift
Spoon Sports
Int-256 dur. / 11.5mm lift
Exh-245 dur. / 11.1mm lift
JUN Type 2
Int-267 dur. / 12.0mm lift
Exh-265 dur. / 10.9mm lift
Skunk2 Stage 2
Int-266 dur. / 12.3mm lift
Exh-262 dur. / 11.8mm lift
JUN Type 3
Int-265 dur. / 12.0mm lift
Exh-265 dur. / 11.5mm lift
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
__________________________________________________ ____
Cams Measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Crower 400
Int-279 dur. / 10.7mm lift
Exh-280 dur. / 9.6mm lift
Spec)
Int-278 dur. / 11.5mm lift
Exh-280 dur. / 10.5mm lift
Crower 401(NA Version)
Int-282 dur. / 11.3mm lift
Exh-277 dur. / 10.5mm lift
Crower 401-T(Forced Induction Version)
Int-280 dur. / 11.8mm lift
Exh-276 dur. / 11.3mm lift
Toda Spec A
Int-290 dur. / 11.6mm lift
Exh-280 dur. / 11.2mm lift
Crower 402(Both Regular 402 and 402-A, 402-A is milder
off VTEC)
Int-297 dur. / 11.8mm lift
Exh-287 dur. / 11.8mm lift
Toda Spec B
Int-295 dur. / 12.0mm lift
Exh-285 dur. / 12.0mm lift
Crower 403
Exh-293 dur. / 11.8mm lift
Toda Spec C
Int-295 dur. / 12.5mm lift
Exh-295 dur. / 12.5mm lift
Old Oct 21, 2002 | 10:15 PM
Default Re: ITR cams vs. CTR cams (eg6ajk)
happy list of lobed goodness
Old Oct 22, 2002 | 11:29 PM
xchosun1x's Avatar
Default Re: ITR cams vs. CTR cams (MikeSarr_GSR)
the CTR cam intake and exhuast cams are morea aggressive than the ITR...
i had a set up of CTR intake and ITR exhuast cam...
which can be pruchased at dealer.... the 99+ ITR intake cams are at CTR spec......( i believe)
with the cams....sprockets , vtec and fuel tuning...
i made an awesome 15 WHP hi end and 25 WHP midrange...
for OEM cams....its awesom.....!!!!
Old Oct 23, 2002 | 05:25 AM
paulITR's Avatar
Default Re: ITR cams vs. CTR cams (xchosun1x)
Do you want to say that the 15 WHP hi end and 25 WHP midrange gains were with the CTR over the ITR intake cam?
Can you show us a dyno graph?
Old Oct 23, 2002 | 07:15 AM
AtomiK_EK's Avatar
I would choose the CTR cams. But I am also selling my used Skunk2 Stage 1 cams which are a little more aggressive than the CTR and ITR. Anyone interested please feel free to email me.
Old Oct 23, 2002 | 09:45 AM
redline201's Avatar
Default Re: ITR cams vs. CTR cams (AtomiK_EK)
25 whp just with the cams, gears ,and tuning????
is this bs????
Old Oct 23, 2002 | 09:49 AM
mRvYbEs's Avatar
Does anyone have the toda spec B's?
I heard that they make the car idle lumpy. Is this true?
Old Oct 23, 2002 | 11:51 AM
Integ_TypeT's Avatar
Default Re: ITR cams vs. CTR cams (MRVYBES)
I have the Spoon cams in my B18 and the idle isnt that rough, every now and then especially when the car is cold, my idle will jump up and down a little, but I really could care less about that, the power they gave me is definitely worth the minor trouble of idle. Oh by the way, valve springs ARE recomended with camshafts!! just a reminder!
Old Oct 23, 2002 | 05:01 PM
StorminMatt's Avatar
The CTR intake cam is slightly more aggressive than the ITR intake cam. But the exhaust cams are the same. Also, the CTR intake cam works great in a B16A without tuning. But the ITR cam must be tuned to work optimally. Finally, the ITR intake cam causes a dead spot in the power curve around 4500-5000RPM. The CTR intake cam does not.
99fbpem1
May 1, 2009 09:22 AM
b18c1sircivic
Apr 8, 2008 04:49 PM
dornon13
Jul 17, 2004 11:48 AM
kenepo_vtec
Jul 4, 2004 08:57 PM
498GSR
Oct 28, 2002 10:06 PM
