Tire balancing question
Old Oct 18, 2002 | 10:39 PM
CHRIS 1.8's Avatar
Default Tire balancing question
I was wondering what it looks like to have your tire balanced and what they put on your wheels. I had my old tires that were on steelies and they put these metal clamps on them before which looked wack.
I have some rims now and I need to get my tires balanced, so I was wondering are they going to do the same thing? Any pics would be helpful
Old Oct 18, 2002 | 10:44 PM
GSRrR's Avatar
Default Re: Tire balancing question (B16A1-EF8)
nope. most likely they will use sticky weights and put them on the inside of the wheel. Sorry no pix.
Old Oct 18, 2002 | 10:48 PM
CHRIS 1.8's Avatar
Default Re: Tire balancing question (GSRrR)
So they all use the same thing to balance tires?
Old Oct 18, 2002 | 11:21 PM
vtec.dc2's Avatar
the metal clamps weights go on outside of the wheel, which should allow a better balancing job.. - not a good idea since they can leave a mark
sticky weights go on the inside of the wheel - most places should have these - i suggest your request for these, so they don't have to guess on what kind of weights you want.
Old Oct 19, 2002 | 12:01 AM
CHRIS 1.8's Avatar
Default Re: Tire balancing question (vtec.dc2)
Are sticky weights expensive?
Old Oct 19, 2002 | 01:19 AM
EndlEEsss's Avatar
YO OC, im mounting and dismounting tires tommorow at Robotech.
I hate that place but at least they only charge 8 bucks to do it, balancing included.
goodyear in tustin was gonna charge me 100 to do all 4, freaking NUTTS
so try the place.
Old Oct 19, 2002 | 02:17 AM
94gsr's Avatar
Tire balancing is universal. The clamp-style weights, (the ones that were on your old rims), are the most commonly used as they are the quickest & easiest to work with. As was already stated, make sure that you REQUEST them to use the stick-type weights & do a normal balance, (weights on the inside & outside of the rim). It'd be a good idea to ask them if the rubber guides on their machine are in good working order - if they aren't you may get your rims back with scratches all around the edges.
Old Oct 19, 2002 | 08:19 AM
vtec.dc2's Avatar
they should charge same price for either way, if its more than $40-50 per 4 tires, i'd go to another place
Old Oct 19, 2002 | 08:50 AM
CHRIS 1.8's Avatar
Could low tire air pressure cause your steering wheel to shake a little as well?
Old Oct 19, 2002 | 10:05 AM
vtec.dc2's Avatar
if its really low then it could increase steering wheel shake. Uneven tire pressure could also play a minor part. For me, if tires aren't balanced well, they shake less when i set the pressure to minimal (within safe specs).
Old Oct 19, 2002 | 01:54 PM
EndlEEsss's Avatar
FOLLOWUP:
i jsut went to robotech, they charged me $40 to dismount a set and mount it on another set and balance them. not to shabby.
Old Oct 19, 2002 | 04:50 PM
CHRIS 1.8's Avatar
Default Re: Tire balancing question (TweakMeUp)
Yea, I got mine done this morning for $40 also.
revemoto
Jul 21, 2009 03:35 PM
allshownogo
Jul 19, 2008 07:58 AM
07SIcpe
Mar 21, 2008 01:44 PM
yaoming315
Jun 1, 2007 05:56 PM
mwieczorek43
Oct 26, 2004 03:32 PM
