Camber Kits
Old Oct 15, 2002 | 09:46 PM
SMZ GSR's Avatar
Default Camber Kits
Hi guys, well this week i'm installing H&R sport springs (1.75"F/1.5"R) and KYB AGX on my 98 GSR. Now my problem is that i know after the springs settle i'll have some camber issues. First question is how bad will the camber be? Second question is what camber kits do you guys recommend i get to go with this setup? Any and all info would be greatly appreciated. Thanks.
Sergio
Old Oct 15, 2002 | 10:15 PM
sgT's Avatar
sgT
Default Re: Camber Kits (SMZ812)
you wont have camber issues. you will have TOE issues. get an alignment done
and you will be fine.
Old Oct 15, 2002 | 10:41 PM
TimoneX's Avatar
New User
Default Re: Camber Kits (sgT)
I have Ingalls with urethane bushings all the way around, but you can easily skip the rear kits and just put washers in there. Your camber will change your toe and you should get an alignment immediately after installing whichever camber kits you go with.
k215
Honda Civic (2006 - 2015)
Mar 19, 2010 03:03 PM
SMZ GSR
Oct 16, 2002 02:24 PM
Racer
Sep 25, 2001 09:37 PM
