NEED wiring help , IAC
Old Oct 18, 2002 | 04:54 AM
LSturboHB's Avatar
Default NEED wiring help , IAC
Car : 98 DX civic HB
motor : 00 B18C5, with JDM ITR ECU
wiring harness: stock civic with extra wires added in.
Full ODB2
Problem: i am throughing a code 14, which ic the IAC valve. on the civic harness there is a 3 wire assembly, on the ITR there is a 2 wire assembly. 2/3 wires color codes match up the 3rd is a orange.
WHAT DO I DO WITH THAT 3rd WIRE???
please post.
thanks
LSturboHB's Avatar
Default Re: NEED wiring help , IAC (LSturboHB)
we tested the IAC and yes it works
Old Oct 18, 2002 | 09:03 AM
LSturboHB's Avatar
Old Oct 18, 2002 | 09:25 AM
Kataku2K3's Avatar
If you haven't already rewired and pulled the pins from A13 (IAC +) and A14 (IAC -) then that's most likely your problem. You'll need to see what wire you ran from the IAC itself to the ECU. Just remember what color it is basically and that should do. When i dropped my friends GSR into his EK i used the orange wire off the IAC. Once you have all that done and figured out just make sure you are in pin A12. That's all there really is too it, let us know how it goes.
Old Oct 18, 2002 | 06:36 PM
LSturboHB's Avatar
Default Re: NEED wiring help , IAC (JDMspecEG6)
anyone have a diagram ?
LSturboHB
Oct 6, 2009 04:03 AM
IGGY
Oct 10, 2006 09:46 AM
si0385.
Aug 21, 2006 05:29 PM
MisterHYBRID
Audio / Security / Video
Aug 28, 2003 07:47 AM
c1civic
Sep 16, 2002 11:54 AM
