remiving cam caps
Old Oct 16, 2002 | 04:24 AM
DOHC-DX's Avatar
Default removing cam caps
[edit] sorry about the title typo... i can't speel
i installed some cams this weekend, and it was pretty easy (LS)
i spent the most time getting the cam caps off the head. on all the how-to's i had seen they talked about using a screwdriver to pry them off. i tried that and nearly ruined one of the caps seeing that the aluminum is so soft.
well, i found the only way to get them off was to take a hammer and tap each one from varying angles until it loosened. is this the wrong way to do it? i can see that if you hit them too hard you could warp them.
any thoughts? is there any other way to do it?
[Modified by DOHC-DX, 1:25 PM 10/16/2002]
Old Oct 16, 2002 | 06:56 AM
IN VTEC's Avatar
Default Re: removing cam caps (DOHC-DX)
plastic hammer and a cloth over it.
A quick tap and you should be able to wiggle off teh caps by hand.
Tim_EG
Oct 8, 2012 08:01 PM
ej1252
10
Nov 21, 2007 11:31 AM
freeagent32
12
Jul 13, 2005 03:55 PM
216.226.142.95:27016
Jun 27, 2003 10:22 PM
CrazyKoreanCrx
May 31, 2003 02:05 PM
