D17 compair to D16?
Old Oct 15, 2002 | 01:29 PM
Spade's Avatar
Default D17 compair to D16?
Anyone know if the deck height is the same on both the D16's and the D17's?
Just wondering if the Crank will fit into a D16Y8.
Reason: Have a D16Y8 block with a bad crank in it and might as well see if I cannot fit a D17 crank in there.......anyone been able to get there hands on one yet?
Old Oct 15, 2002 | 01:31 PM
tmg's Avatar
tmg
Default Re: D17 compair to D16? (Spade)
sorry man? if you can find some detailed engine specs, that should tell you.
Old Oct 15, 2002 | 01:49 PM
freakin_eLRoD's Avatar
Hey Spade check out the dseries board, I could've sworn I heard someone talking about using the d17 crank as an oem stroker kit for the sohc's....
Old Oct 23, 2002 | 08:52 PM
Spade's Avatar
Default Re: D17 compair to D16? (ridge racer 2)
bad move cojack.
At least explain that.......
I am thinking that the bore is larger on the 17's and it isn't the crank.
Old Oct 23, 2002 | 11:53 PM
kinesistech's Avatar
Just use the whole d17 block. The rod length is almost garunteed to be a different length. I seriously doubt that Honda changed the bore size on the same engine design they've been using since '88.
trav39562
Jan 27, 2009 04:58 PM
Swipe'd
Sep 17, 2007 05:10 PM
dohdoh420
Dec 1, 2005 01:13 PM
Spade
Nov 27, 2002 02:28 PM
