Tranny: The truth about synchros?
Hey guys,
My tranny works perfect but It seems like my 2-3 synchro is out. It mis shifts everytime i'm near redline (2-3 only)
I was told the you cannot just change synchros... you have to buy the whole assembly inlcuding gears etc. ($500+USD)
So my question is:
Is this true(synchros)? price sound right?
Can you buy stronger/heavyduty synchros/gears?
(I dont wanna buy a used tranny... i've bought one from a del sol vtec that's siezed inside and now i gotta return it :crook
So my question is:
Unless the lack of synchro damaged something, there is nothing else to replace. Call a Honda dealership and ask what just the synchro cost, that is where the shop has to buy it from.
Part of the synchro is actually part of the gear- so yes it will be pricey. I would also recommend replacing your input shaft bearings at the same time- or at least the front bearing.
in all honda trans you have to buy the gear set to get the syncro/ yours will need 3rd gear set. about $175 for the parts plus installation
sorry about bad info, I must of been thinking of something else. I have a y1 now and pretty much all of my synchros are gone, so I am just going to start over. but good luck anyway.
Ok, that sounds about right.
If the tranny is cracked open, can you see physically if other synchro/gear sets would have to be replaced too? 4-5 also grinds ocasionally.
TIA guys.
TIA guys.
S2KBAR
Oct 27, 2006 11:06 AM
CrX-To-Tha-Max-v2.0
Apr 13, 2005 12:23 PM
