Carbon buildup on pistons
Old Oct 3, 2001 | 08:43 AM
KayOs's Avatar
Default Carbon buildup on pistons
I want to clean the dirty carbon deposits that cover the top of my P30 pistons. What do I clean and remove the deposits with?
Old Oct 3, 2001 | 12:38 PM
rainforest's Avatar
Default Re: Carbon buildup on pistons (KayOs)
are you going to run the pistons or sell them. Because having small carbon deposits on the piston is good for heat transfeer.
Old Oct 3, 2001 | 01:09 PM
martini's Avatar
well rain, it also helps with predetonation if it gets bad.
don't use an abrasive pad that will scratch the surface, you'll do more harm than good. Automatic Transmission Fluid works well.
Old Oct 3, 2001 | 05:26 PM
KayOs's Avatar
I am going to run them. Just thought I would clean them since the head is off the block. But if it helps I guess I will leave it alone.
Old Oct 3, 2001 | 06:27 PM
dustin's Avatar
I would clean them if I were you. Chemtool works quite well
Dustin
Old Oct 3, 2001 | 08:36 PM
KayOs's Avatar
What is Chemtool ? How is it used. Thanks.
Old Oct 4, 2001 | 12:22 AM
dustin's Avatar
Chemtool is a solvent you can buy at an autoparts store for like $3 a can. It cleans carbon up really well.
Dustin
Old Oct 4, 2001 | 06:24 AM
Spade's Avatar
Default Re: Carbon buildup on pistons (dustin)
He says that he has the head off....so if you use this solvent to clean the pistons while they are still in the block is that going to be a problem?
Old Oct 4, 2001 | 08:00 AM
dustin's Avatar
Default Re: Carbon buildup on pistons (Spade)
it is fine if the motor is like, not assembled and has no oil in it. Else I would not let solvents get in the motor unless you were very careful.
Dustin
Old Oct 4, 2001 | 09:12 PM
Louie's Avatar
What would Chente do?
GM top clean is a very strong carbon cleaner. Just spray it on and let it sit.
Cheap too. Just don't get any in your eye.
Old Oct 4, 2001 | 10:12 PM
976's Avatar
976
New User
Default Re: Carbon buildup on pistons (vagoITR)
ATF, after you use, drive around you city and give everyone a taste of burning carbon build-up. Cops might pull you over because of all the smoke, tell him/her to shut up!
dem0nk1d
May 22, 2012 10:00 PM
EK FLY
Jan 31, 2006 05:42 PM
dubnine
Mar 26, 2004 10:22 AM
hondaeg8
Jan 6, 2004 05:08 PM
