How the hell do you seperate the tranny from the engine?
Old Oct 9, 2001 | 04:24 PM
AshlandSi's Avatar
Default How the hell do you seperate the tranny from the engine?
Is there a trick to it?
I took a crowbar to it and it wouldn't budge.
Are there hidden bolts?
Does it have to be in a certain gear?
TDC on the engine?
Help!
Old Oct 9, 2001 | 04:28 PM
VTC_CiViC's Avatar
Default Re: How the hell do you seperate the tranny from the engine? (AshlandSi)
Sounds to me like you missed a bolt. Check over the entire tranny housing VERY thouroghly, and don't forget to remove the starter before you remove the tranny! Once you have every bolt off, the tranny should slide right out (did for me).
Old Oct 9, 2001 | 04:34 PM
AshlandSi's Avatar
Default Re: How the hell do you seperate the tranny from the engine? (VTC_CiViC)
I pulled 7 17mm bolts. Are there any others?
Any smaller ones?
I'm going to check again.
Old Oct 9, 2001 | 05:49 PM
AshlandSi's Avatar
Ok, I got the engine and tranny seperated. However, I still have a little problem. The shift rod is secured by a little alligator-toothed rod thingy. How do you get that out?
Old Oct 9, 2001 | 06:29 PM
fixhondas's Avatar
a pin punch and hammer will work- I use an air hammer with a valve guide driver. Don't lose it!
Old Oct 9, 2001 | 06:31 PM
AshlandSi's Avatar
Default Re: How the hell do you seperate the tranny from the engine? (fixhondas)
Hmmm....that little bugger must be in there tight! I stripped a punch already trying to get it out.
Old Oct 9, 2001 | 07:35 PM
flex97itr's Avatar
good luck... i hate taking that thing out!!! use a punch and a hammer
Old Oct 9, 2001 | 08:40 PM
boomslang's Avatar
Sounds like you missed the long *** starter bolt.
Old Oct 10, 2001 | 06:13 AM
owen_the_soyboy's Avatar
Default Re: How the hell do you seperate the tranny from the engine? (Loco Honkey)
that pin was the worst part for me, took an hour, I should have just drilled the bastard out or flipped th ecar over to just use a sledgehammer on it.
good luck!
Old Oct 10, 2001 | 06:34 AM
VTC_CiViC's Avatar
Default Re: How the hell do you seperate the tranny from the engine? (owen_the_soyboy)
#1- Acquire stick of dynamite
#2- Place dynamite in stategic location between the pin and the shifter rod
#3- light dynamite fuse
#4- Run like there's no tomorrow
Pin should pop right out
Old Oct 10, 2001 | 09:20 AM
AshlandSi's Avatar
Yeah, I have the tranny sitting on the ground now but that little bastard pin doesn't want to budge. Am going to try the brute force method again today, and if it doesn't come out I'll need to get creative
Old Oct 10, 2001 | 09:42 AM
RyanR's Avatar
The only way I got that ******* bitch pin out was by dropping the tranny with the shift rod still attached and using a punch and a 10lbs sledge hammer and just pounding the **** out of it. Even with the sledge it still took about 5-6 good wacks before the pin started moving.
Old Oct 15, 2001 | 06:55 PM
BreakStuff's Avatar
New User
Default Re: How the hell do you seperate the tranny from the engine? (97TypeR_9)
I usually drop the tranny with the shifter rod attached and work around it, unless you have to split the tranny case, then it must be removed..
petty$rep
Oct 6, 2006 01:18 PM
SuperDuude
10
Jul 1, 2004 09:24 AM
integraGSR213
Feb 16, 2004 11:19 AM
mingchi69
Sep 8, 2003 10:58 PM
civickiller
10
Aug 12, 2003 12:44 PM
