clutch problem
Old Oct 10, 2001 | 03:38 PM
solsearching's Avatar
New User
Default clutch problem
I replaced my clutch disc, pressure plate, and release bearing on my del sol. After everything was done, I went to press the clutch pedal in and had no pressure whatsoever. I noticed there was some fluid leaking from the slave cylinder so I just replaced that and tried bleeding everything thoroughly. I still have no pressure on my pedal. WTF could I have done wrong?
The release fork seems to slide back and forth freely. With the old slave cylinder in and the car running, I could put it in gear even with very little pedal pressure. I tried the same situation with the new cylinder and I can't even get it in gear.
Old Oct 10, 2001 | 03:50 PM
976's Avatar
976
New User
Default Re: clutch problem (solsearching)
You need to bleed your clutch of oxygen. Take a small tube and connect it to your slave cylinder, there is a small PSI line that allows you to do this. Then put tube in brake fluid, and pump clutch until' all the "bubbles" are out. Good luck, you will see what I mean when you look at your slave cylinder.
Old Oct 10, 2001 | 04:55 PM
New User
I tried already tried that. I don't really know how it would be air in the lines in the first place though because before I changed the slave cylinder, it still didn't have any pressure.
stock95civic
Mar 12, 2007 10:55 PM
ge_itr
Oct 5, 2006 01:24 PM
T"u"Rtle
Apr 21, 2006 10:17 AM
Flamenco-T
Feb 16, 2003 06:38 PM
Flamenco-T
Feb 16, 2003 03:58 PM
