Are injectors OBD specific?
Old Oct 12, 2001 | 08:18 AM
Powered by Honda's Avatar
Default Are injectors OBD specific?
I need someone to confirm this. But for example, there is no way to get OBDII ITR injectors to work on an OBDI GSR right? Thanks for any info...
Old Oct 12, 2001 | 08:38 AM
sgT's Avatar
sgT
Default Re: Are injectors OBD specific? (MugenHondaFormula1)
saturated injectors will work in any saturated system and peak hold injectors will
work in any peak hold system. You can use one in the other but that is another
lesson in itself.
92+ integra/civic injectors are all the same. In 96 the plug got changed so if you change
the plugs to match then they will work just fine.
Old Oct 12, 2001 | 02:26 PM
GruvyTune's Avatar
New User
Default Re: Are injectors OBD specific? (sgT)
The injectors are the same but the clips are different. I have 2001 type R injectors running on my 95 GSR. I had to solder in OBD2 clips but the actual injector is the same.
I am selling them on ebay if interested!~!
http://cgi.ebay.com/ebaymotors/aw-cg...ndexURL=0&rd=1
Old Oct 12, 2001 | 10:07 PM
Giuseppe's Avatar
how can i hook up
h22 310 peak and hold injectors in my
1990 civic with 1st gen b16a
doodooheadfart
Feb 22, 2007 09:53 PM
MidoriEK4
Mar 2, 2003 02:53 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
