CTR cams in B16A engine - what else do I need?
Old Oct 10, 2001 | 06:53 PM
sneakychaos's Avatar
Default CTR cams in B16A engine - what else do I need?
My bro has a 99 Civic SI and he got a set of CTR Cams for it. Currently, the only mods are AEM CAI, and AEM Cam Gears. Valvetrain and full exhaust are both stock.. what else does he need to get the car tuned/running right. Are there do's and don'ts I could let him know about? Free'r flowing exhaust help? Any valvetrain upgrades required, or are the stock internals ok to handle them?
Old Oct 10, 2001 | 08:19 PM
Finest's Avatar
Default Re: CTR cams in B16A engine - what else do I need? (trooth)
I would at least finish up with all the bolt-ons before jumping into the cams. An exhaust is mandatory, as well as headers.
As far as the internals go, they're fine. Keep the rev-limiter stock and you'll be okay. If you want to raise the limiter, you might want to invest in some stiffer valvesprings.
Also, I would add a fuel controller of some sort. A simple fuel pressure regulator would work, but an S-AFC would be better.
And the most important thing is to get it DYNO TUNED! A few hours on the dyno can help squeeze out the last few remaining hp hidden in those cams.
Good luck.
Old Oct 10, 2001 | 08:58 PM
H23 Power's Avatar
Default Re: CTR cams in B16A engine - what else do I need? (Prelude_RCR)
cam gears
Old Oct 10, 2001 | 09:18 PM
GSpeedR's Avatar
Default Re: CTR cams in B16A engine - what else do I need? (01GSR)
I would upgrade the v-train to at least ITR-spec. The CTRs have been shown to make power up to around 8800rpm, so with the addition of cam gears, you should see a good improvement with some dyno time.
Also, look into possibly an ITR manifold (I know it fits the b17a). It's cheaper than the Skunk2, and the B16a has the same head as the B17a. You will need a G2 LS fuel rail for proper fitment.
Old Oct 11, 2001 | 05:36 AM
Default Re: CTR cams in B16A engine - what else do I need? (GSpeedR)
Well, I talked to him today and the ITR Intake Manifold should be in friday. I'll let him know about the fuel rail.
01GSR : thanks for the advice, but if you didnt read the post it said I already have the cam gears. You have any advice for settings?
Thanks for the help guys.
Old Oct 11, 2001 | 09:34 AM
H23 Power's Avatar
my bad...
advice for settings? hit the dyno, there is no other way to set them accurately
Old Oct 11, 2001 | 02:20 PM
Figured as much.. but thanks anyway. Hopefully once he gets everything else, he'll be at the dyno. Thx.
Old Oct 11, 2001 | 06:00 PM
blkDOHCsol's Avatar
New User
I have a R manifold on my b16..you need a crv IACV or PCV or something like that..forgot, its been like 1yr since i put it on..id also upgrade valvetrain..good luck
1SikEagle
29
Jan 14, 2012 05:09 PM
grunt111
Oct 20, 2011 04:59 PM
99 TYPE R
May 2, 2004 02:00 PM
KayOs
Aug 3, 2001 07:29 PM
VTECAcuraGSR
Jun 17, 2001 06:18 PM
