Timing and TDC questions?
Old Oct 2, 2001 | 07:09 PM
[626] SiRJKwIcK89Ef's Avatar
New User
Default Timing and TDC questions?
Ive just installed a d16z6 head.. my distributor is off, my timing belt is off, and my head still needs to be torqued to spec.. how do i get my engine to TDC and how do i do my timing?
Old Oct 2, 2001 | 09:09 PM
KayOs's Avatar
Default Re: Timing and TDC questions? ([626] SiRJKwIcK89Ef)
Before taking off the head you should of set the motor to TDC.
Since you did not then you will have to turn the crankshaft pulley in a counterclockwise direction until the number 1 piston is at the highest point in rotation (number 1 piston at TDC). You can verify this by feeling for the #1 piston.
Align the white mark on the crankshaft pulley to the mark on the lower timing belt cover. This will help you determine if #1 piston is at TDC.
swizz977
Apr 19, 2015 09:04 AM
potatointegra01
Apr 6, 2015 05:48 PM
Jabuuty671
30
Feb 27, 2012 01:12 AM
Boostedb20EH2
10
Mar 10, 2008 04:36 PM
OBD-One-Kanobe
Nov 1, 2002 09:21 AM
