Need more power
Old Oct 4, 2001 | 12:01 PM
ZUL8R's Avatar
Default Need more power
what else can i do besides I/H/E on my 98 Civic DX to get some more juice that wont cost an arm and a leg.. fuel rail, pullys, will these help any?? thanks
Old Oct 4, 2001 | 02:06 PM
fixhondas's Avatar
Default Re: Need more power (shane89z24)
get a cam- pulleys and **** are really slight tweaks. fuel rail wold be the last thing on my list- right next to billet oil cap.
Old Oct 4, 2001 | 02:16 PM
VTC_CiViC's Avatar
Disconnect your PS pump belt, advance your timing, give the car a thourough tune up and make sure all parts are up to spec. You'd be supprised what a little tweaking here and there can do for how your car feels.
Old Oct 4, 2001 | 07:09 PM
4wsB21a's Avatar
New User
if you have the ability to do so, lighten your flywheel. have a garage turn it like a rotor to shave off as much as you can - just remember not to shave off too much, or you will be replacing your clutch and flywheel before too long. the cam is a good idea, but you need to be careful of that - you can run into idle problems with the different cams. we had to adjust our idle to be over 2000 rpms for the crx that we put the racing cam in for autoxing. other than that, just the tune-up and timing advance will help. just remember, the timing advance will make you lose some low end power too. but the top end power will be worth it!
Old Oct 4, 2001 | 07:30 PM
Dr Pooface's Avatar
Default Re: Need more power (crxplus)
NAAAAAWWWWWWWWWWWS
Old Oct 5, 2001 | 05:47 AM
Muckman's Avatar
Moderator in Chief
Default Re: Need more power (Dr Pooface)
*shudder* I hate that word "NOZ"
but hey Nitrous is a cheap way to get a boost in HP. If you just want it for street applications - stoplight racing. Go get yourself a NOS kit. Wet is better but prob more complicated to install and more $$. Dry is fine if you going with a small shot. Venom sells good computerized kits.
Old Oct 5, 2001 | 11:39 AM
EVOCELICA's Avatar
New User
Default Re: Need more power (Muckman)
Buy a NOS dry manifold kit
Best bang for the buck
Just make sure you buy the right kit. NOS makes wet kits but they are only to be used with a turbo or supercharger. The kit you will want to purchase is going to be a dry manifold kit like the one pictured above.
[Modified by EVOCELICA, 8:40 PM 10/5/2001]
Old Oct 5, 2001 | 12:13 PM
Kamin's Avatar
Default Re: Need more power (EVOCELICA)
nos is cheating
its like using a bike.
j/k if you want nos go for it. the dry kit.
Old Oct 5, 2001 | 12:17 PM
falcongsr's Avatar
What is this crap?
Default Re: Need more power (KAMiN)
you're in the wrong forum. come to Forced induction. it wont cost an arm and a leg. i have all of my appendages still...
b18c1civic95
Jan 1, 2007 06:25 PM
InvaderTrax
Jul 16, 2006 02:18 PM
boostking
Oct 26, 2005 01:18 PM
ONE.SIX SI
Aug 1, 2003 12:35 PM
PatrickGSR94
Apr 11, 2003 04:21 PM
