Torque and horsepower curve data
Old Oct 8, 2001 | 04:43 PM
physprof's Avatar
New User
Default Torque and horsepower curve data
Does anyone know where I can find curves of horsepower and/or torque as a function of engine rpm for various throttle positions for my 2000 Honda Civic engine?
Old Oct 8, 2001 | 07:00 PM
Jared's Avatar
Default Re: Torque and horsepower curve data (physprof)
no way to tell, all engines are different.
Old Oct 8, 2001 | 07:52 PM
Christine's Avatar
New User
Try this site... mostly for Integras but I think I remember seeing some other stuff on there too.
http://www.geocities.com/dynocenter/home.html
It doesn't matter what you see there though, your car will most likely be different.
Old Oct 8, 2001 | 08:39 PM
GSRMatt's Avatar
25 Year Member
Default Re: Torque and horsepower curve data (Christine)
You're likely to only find WOT curves anywhere public. For part throttle data you'll have to be in contact with Honda engineers or someone who does relatively serious emissions testing/verification with a load-bearind dyno. If you call around local shops ask if they have a Mustang or Dynapac dyno (or any other load bearing one for that matter). Rates are usually near $100/hr or so to make them yourself.
Try a search on this site, wot dyno plots are posted fairly often. Depending on how sophisticated/accurate you want to be, you can figure out the choke point of the throttle at various percentages, and the airflow vs rpm based on the VE of the engine, to extrapolate the partial throttle curves from WOT. Basically they'll ramp up about the same until you near the throttle limitation, then run flat out to redline.
Good luck.
gnarlycs
12
Jun 3, 2012 04:33 PM
brian91accord
Aug 23, 2009 05:49 PM
JTRO15
Honda Civic (2006 - 2015)
21
Apr 17, 2009 09:55 PM
edulerp97
Mar 6, 2005 02:55 PM
Toolman
Dec 27, 2004 12:03 PM
