GD MF POS AXLE NUT!!!!
Old Oct 12, 2001 | 02:33 PM
DragII's Avatar
25 Year Member
Default GD MF POS AXLE NUT!!!!
Ok...those of you who have been following know I have broken a half inch drive breaker bar, and ratchet on this bastard...now I just finished trying to TORCH the ****, and it STILL WON"T BUDGE....WTF can I do???
Old Oct 12, 2001 | 02:35 PM
Spade's Avatar
Default Re: GD MF POS AXLE NUT!!!! (DragIIcivic)
Dude, can you get an air gun? That is all I can think of. RENT one if you can't buy it.
Old Oct 12, 2001 | 02:38 PM
DragII's Avatar
25 Year Member
Default Re: GD MF POS AXLE NUT!!!! (Spade)
I'm gonna rent one tommarrow...if that doesn't work I'm gonna cut the MFer off...I'm sick of this problem
Spade's Avatar
Don't blame ya.....just remember to use the hell out of the air gun
Old Oct 12, 2001 | 06:26 PM
BreakStuff's Avatar
New User
ok DragII.. When using the torch you should concentrate the flame on the nut itself and getting the nut "cherry red" hot, and keep the flame away from the axle stem.... This will expand the nut and help in getting it loose.. the nut should come loose in this case.. Forget about air guns, I've broken a hella lot more bolts with my hand tools than I have with my assorted combination of air tools.. air tools have "hammer" impact w/ short blows... 1/2 isnt gonna do it.. like I said prior, only 3/4 or 1" impact air gun will break a stubborn nut like that loose, these particular guns are rather expensive and run $400+
Trust me, there is a chance you may waste the wheel bearing, but if you get the nut red hot it will come loose...
Old Oct 12, 2001 | 06:39 PM
DragII's Avatar
25 Year Member
what is included in removeing the hub assembly? I might just buy new hubs and bypass this whole ordeal...thanks for the info breakstuff
Old Oct 12, 2001 | 09:12 PM
HXMan's Avatar
That thing is still stuck on there! WOW!
Old Oct 12, 2001 | 10:21 PM
Kamin's Avatar
Default Re: GD MF POS AXLE NUT!!!! (HXMan)
damn drag
time to get the fix-all tool
the sledge hammer.
Old Oct 13, 2001 | 09:51 AM
One8Hatch's Avatar
New User
Default Re: GD MF POS AXLE NUT!!!! (KAMiN)
did you remove the little part thats indented into the axel? just stick a flathead in there and hammer, it will make it easier to get off.
Old Oct 13, 2001 | 03:33 PM
DragII's Avatar
25 Year Member
Default Re: GD MF POS AXLE NUT!!!! (One8Hatch)
yup did that
trying some penetrating oil now...running out of Ideas, and ready to start cuttin
Old Oct 14, 2001 | 11:03 AM
Suprdave's Avatar
Hmmm....I went through the Same Problem...
Ended up Cuttin it off with a Carbide Cutter thingy...
Suprdave
Old Oct 14, 2001 | 02:19 PM
clockworks's Avatar
First time I had to take one off, I snapped a 1/2" breaker on it. I had a 1/2" electric impact with me, but I wanted to see just how tough that nut was. Anyway, that electric impact had some *****, it took it off in 2 seconds. Most rental places have electric impact wrenches so you won't need to get the compressor. Good luck.
Old Oct 14, 2001 | 03:27 PM
Honda4CX-T's Avatar
BIG FAT TIP For YA !!!!
Impact Wrench !!! Comes out in (2) Seconds !!! or LESS !!!
Old Oct 14, 2001 | 05:06 PM
SCsol's Avatar
Default Re: GD MF POS AXLE NUT!!!! (Honda4CX-R)
if that dont work this will %100 , i had tis problem before get your friend in the car and put his foot on the brake as hard as he can then put a large PIPE werench ( visegrips wont work) on the SOCKET then put a 4 or 5 foot bar on the pipe werench and your done this will get it off %100 or your money back i hope this helps
Old Oct 14, 2001 | 07:58 PM
Espelir's Avatar
New User
Just for reference sake, its NOT a good idea to use a Impact Wrench on an axel nut, you risk damaging the tranny. Try this, use a 1/2 or even better a 3/4inch drive breaker bar. (Get a craftsman, they dont snap and if they do, you get another one for free!) Take the handle from a floor jack, slide it over the breaker bar, and in effect you get a wrench about 5 feet long, there is no way that that shouldnt take the nut off. Good luck
Old Oct 14, 2001 | 10:35 PM
clockworks's Avatar
Default Re: GD MF POS AXLE NUT!!!! (Espelir)
I'm at a loss; how is it bad for the tranny?
Old Oct 15, 2001 | 06:54 AM
Spade's Avatar
I don't think that Drag wants to get another breaker bar....how many did you break so far Drag? I think that the count is two.
Old Oct 15, 2001 | 08:28 AM
DragII's Avatar
25 Year Member
2 and counting
Old Oct 15, 2001 | 08:40 AM
urbanlegend21's Avatar
New User
use a breaker bar and long piece of pipe on the end..... also what length breaker bar are you using
Old Oct 15, 2001 | 10:44 AM
EVOCELICA's Avatar
New User
Default Re: GD MF POS AXLE NUT!!!! (urbanlegend21)
Bro I had the same problem an air gun couldn't get it loose hand tools where no good. I ended up using a breaker bar and a 6 foot pipe for leverage. I had my homie slam on the breaks and puth the trans in gear. I then squated under the 3 inch 6 foot long pipe and lifted it with my shoulders and pushed with my legs after like 2 tries that bitch came off.
Old Oct 15, 2001 | 12:27 PM
SOHCArchangel's Avatar
Default Re: GD MF POS AXLE NUT!!!! (EVOCELICA)
goooood night!
Old Oct 15, 2001 | 03:21 PM
vtec2nr's Avatar
Drag,
I feel for ya man. I broke two breaker bars on my just this week. I finally coated it in WD40 and let it sit for two days. I put the car on the ground with the rims on it(put some big scratshes in my rims ), and used the jack handle on a rachet. stood on it, and the F*%$ing thing let go, and just unscrewed. Wasn't rusted or anything. I guess what I'm saying is walk away, rethink it, maybe WD40 or some better penetrating oil, and just keep trying.
Best of luck.
-Chris
Old Oct 15, 2001 | 04:08 PM
DragII's Avatar
25 Year Member
Default Re: GD MF POS AXLE NUT!!!! (vtec2nr)
yeah, I got it soaking right now....:frustrated:
Old Oct 15, 2001 | 04:49 PM
SCsol's Avatar
did you try what i told you i will work so dont waste your time doing anything else large pip wrench 24" will work %100 and a 4 foot bar on it you wont slip or break any breakebars
Old Oct 15, 2001 | 04:59 PM
turboEF ZC's Avatar
New User
Default Re: GD MF POS AXLE NUT!!!! (lowsol)
does anyone here know what an impact does? it doesnt put steady pressure on the nut it hits it and hits it. well if you get a mini sleg and breaker bar and about 2 feet of pipe put the 32mm socket on the bar and the pipe over the bar and all this geos on the nut. the your gloved had goes where the bar and pipe go together and then the start to smack the bar over and over and i will bet my car this will work. i call it the poor boy impact it worked for my crank pully nut. give it a try what the hell right?
