removing water spots
Old Oct 15, 2001 | 06:57 PM
redteg1's Avatar
Default removing water spots
i have a lot of water spots on my hood. how the hell do u take them off? is there ANY way to take it off? i've tried soap/water, wax. but nothing seems to work? any ideas?
Old Oct 15, 2001 | 07:07 PM
lazyvietboi's Avatar
Default Re: removing water spots (redteg1)
what??!??! wax didnt work ?!??!!? wtf.. i should work..
Old Oct 15, 2001 | 07:09 PM
redteg1's Avatar
Default Re: removing water spots (lazyvietboi)
nope wax didnt' work...it just made it shiny under the coat...hmm....any other suggestions? o btw i was using mother's carnauba...
[Modified by redteg1, 4:10 AM 10/16/2001]
Old Oct 15, 2001 | 07:17 PM
BreakStuff's Avatar
New User
Those stubborn watermarks are the after effects of acid rain.. Try an electric buffer with a mild cutting creme or rubbing compound.. you will need to "cut" into the clear coat to remove those marks.. You can use baking soda mixed with water, but this method is rather tricky and if you screw up you may be re-painting your car, Try the buffer first
Or just try using a cutting compound by hand and put alot of elbow into it!
[Modified by BreakStuff, 11:19 PM 10/15/2001]
Old Oct 15, 2001 | 07:21 PM
Mr. Thunderlips's Avatar
Default Re: removing water spots (BreakStuff)
yeah...make sure you use a foam pad on the buffer, and not the wooly one...the wooly one will burn through the clear coat in seconds if you dont know how to use it...
Old Oct 15, 2001 | 08:42 PM
digitalspice's Avatar
Banned
Default Re: removing water spots (Slo_Teg)
Try MX-7, I use it and it works like magic, Takes em right off and it is clear coat safe. Make sure you apply a fresh coat of wax after.
The website is listed below.
http://www.mx-7.com
[Modified by digitalspice, 9:43 PM 10/15/2001]
Old Oct 15, 2001 | 10:32 PM
martini's Avatar
I suggest a fine cut cleaner, followed by a polish (you can hand apply), then the wax.
These guys know what they are doing: http://autopia-carport.com/ForumIndex.htm
Old Oct 15, 2001 | 11:19 PM
Anthony K's Avatar
New User
Default Re: removing water spots (martini)
I use meguiar's cleaner wax. I just wax it in REAL GOOD. It takes a while but eventually they come out. I'm sure there's easier ways, but I don't wanna use anything abrasive or dangerous on my paint.
4dek
22
Dec 24, 2010 02:23 PM
ejLday
Detailing
Mar 25, 2009 08:54 PM
1slowcrx
Paint and Body
15
Jan 27, 2008 09:05 PM
Hellzcivic
Honda Civic (2006 - 2015)
16
Nov 22, 2006 06:18 PM
Pure R Racer
Nov 20, 2001 02:33 PM
