No compression in my type r shortblock
Old Oct 11, 2001 | 06:41 AM
FAST94GSR's Avatar
New User
Default No compression in my type r shortblock
I bought it from this guy, and it has been laying in my garage for like 3 months. Well its all put in, and the thing won't start. Did a compression test and it comes out with virtually no compression. I"m like WTF!!!! Visually the block looked brand new. Although I didn't tear it down to see it had piston rings. I assumed they would be there.
There is a couple of possibilities here. 1) rings are stuck 2) piston may be shot from underneath 3) there are no rings whatsoever
Anyone else ever come across this problem?
Old Oct 11, 2001 | 07:07 AM
ZygSpeed's Avatar
Default Re: No compression in my type r shortblock (FAST94GSR)
Sorry to hear that.
I may be looking for something to build up for boost, depending on what you find, and decide to do with that one. /ed
Old Oct 11, 2001 | 08:25 AM
rainforest's Avatar
usually it would be the rings. Did you ever take a comp test before the itr block?
what was the comp then. Also i would kill that guy.
Old Oct 11, 2001 | 09:26 AM
Leo95SE's Avatar
eh? you can see the rings on the shortblock. otherwise the pistons would move around a *bit*, but enough to notice. im sure they were there, could just need replacement..
although - you said the shortblock has no compression, did you put the head on first?
Old Oct 11, 2001 | 10:01 AM
optiontoo's Avatar
New User
Did you check the valve timing?
Old Oct 11, 2001 | 06:03 PM
BoostOptions's Avatar
New User
My first guess would be in the ring lands. The ring lands may have cracks in them and resulting in loss compression. If they are cracked it doesn't always mark up the cylinder walls, so there isn't anyway to tell unless you tear down the block.
Old Oct 12, 2001 | 04:48 AM
DC2_R's Avatar
Another thing to check is to make sure that valve adjusters aren't too tight! Happened to me once.
sh!tsWEAK!
24
Apr 8, 2009 08:28 AM
lilo_goki
Feb 18, 2009 01:56 AM
NegativeXero
Nov 10, 2007 03:57 PM
junkyard racer
Oct 31, 2004 05:32 PM
98civicEX
Apr 8, 2003 10:55 AM
