how to set up fuel maps for VTEC?
Old Oct 3, 2001 | 10:41 PM
max's Avatar
max
Default how to set up fuel maps for VTEC?
i have a mini-me swap. and im getting the v-afc for it. how can i set it up myself to be sure that it doesnt lean out at WOT?
Old Oct 3, 2001 | 10:47 PM
sgT's Avatar
sgT
Default Re: how to set up fuel maps for VTEC? (max)
an AFC wont help you richen at all.
Your best bet is an adjustable fuel pressure regulator.
Old Oct 3, 2001 | 10:49 PM
max's Avatar
max
Default Re: how to set up fuel maps for VTEC? (sgT)
what are u talking about? afc lets u adjust the amount of fuel put in at a given rpm, right?
Old Oct 4, 2001 | 06:07 AM
John's Avatar
New User
The V-AFC unit has a progressive mapping system between what you set as low-throttle air-fuel ratio and high-throttle air-fuel ratio. By default, low-throttle is set at 10% throttle, high at 50%. So you can essentially have two settings for the car, one for around town driving, the other for lead-footing it... That should get you started... it's a pretty powerful and useful tool... I recommend having it tuned on a dyno so that you maximize your power and efficiency by adjusting your air-fuel ratio to stay within the bounds of the ideal air-fuel ratio for the ideal cylinder temperature upon detonation...
Old Oct 4, 2001 | 07:30 AM
max's Avatar
max
Default Re: how to set up fuel maps for VTEC? (DunReit)
yes, i want to get it dyno tuned. but how does that work: do i pay per each dyno run and then tune it myself, or i give them the car and they do it for me? and do u know any plaves in VA that will do it?
Old Oct 5, 2001 | 09:18 PM
DR. ON POINT's Avatar
Banned
inline pro is the best shop in va....check my sig
[Modified by On Point, 6:18 AM 10/6/2001]
Old Oct 5, 2001 | 09:44 PM
max's Avatar
max
Default Re: how to set up fuel maps for VTEC? (On Point)
what did u have done there? how much did it cost?
Old Oct 5, 2001 | 10:35 PM
Turbolude's Avatar
In virginia Beach va there is a chasis dyno at Abucus Racing. 100 per hour and the guy chuck that runs the dyno can help you get it right.
red_ek_hatch
Apr 6, 2005 02:48 PM
94vtecmn
Apr 23, 2004 05:30 AM
killa_lude
Aug 26, 2003 05:10 PM
tc
May 6, 2002 12:25 PM
