Skunk2 Coilover Adjustment Help
Old Oct 16, 2001 | 12:35 AM
IgniteTeg's Avatar
Default Skunk2 Coilover Adjustment Help
I have a question how do I exactly adjust my height the with Skunk2 Coilover????? Also even have the wheel all perfectly lowered at the same height????? How????? I know there is 2 perches. I know I jack up the car first then use the tool to adjust but I don't know what to spin or turn. Which perch do I spin how does each one goes?????? Please tell me how to exactly measure the height for it also thanks for all the help.
Old Oct 16, 2001 | 01:09 PM
misledyouth's Avatar
New User
Default Re: Skunk2 Coilover Adjustment Help (IgniteTeg)
bottom perch isa lockign perch. u undo that one then move the topone where you can it make sure the perches have no dirt in them then you just go my looks no real way to measure.
later
Old Oct 16, 2001 | 04:37 PM
WiZeBaNaNa's Avatar
New User
move the top perch up and lock the bottom perch to it to raise the car... move the bottom perch down and lock the top perch to it to lower the car...
there is no exact ride height type of thing... sorry... its kind of just trial an error... kind of measure where you are right now baseline with the car on the ground from the center of the rim to the top/center of the fender... figure out where you want the entire car to be and lower your perches accordingly at each corner... it may take an adjustment or two to get it exactly where you want it... just get out there and get dirty...
scussett
Dec 5, 2004 08:06 PM
b00sted4dr
Oct 8, 2004 12:00 AM
civic_tko
Nov 13, 2002 12:52 PM
IgniteTeg
Oct 16, 2001 05:52 AM
