damn emissions testers!!!
Old Oct 4, 2001 | 11:35 AM
JunkeeCrx's Avatar
New User
Default damn emissions testers!!!
why do they care if my NOX level is .5 to high!!! ASSES!!
anyways now to the question. I know my egr system is slightly messed, and i have to put a new distributor on so i can get my timming corrected. So do i do the ole' 3 bottles of alcohol on the tank to pass, or do i fix the egr and distr. then go get it tested? tell me what you all think! any help/advice would be great.
[Modified by JunkeeCrx, 12:35 PM 10/4/2001]
Old Oct 4, 2001 | 11:38 AM
John's Avatar
New User
Default Re: damn emissions testers!!! (JunkeeCrx)
it could be something even more simple... just have the car warmed up perfectly... you can't let the car idle too long before the test, and you can't let it sit too long off before the test, and be sure that you've driven your car at least 10 miles before you get to the emissions inspection station.
Old Oct 4, 2001 | 11:42 AM
JunkeeCrx's Avatar
New User
Default Re: damn emissions testers!!! (DunReit)
it was warmed up plenty, although i did leave it running while i was in line before the test.
Old Oct 4, 2001 | 11:46 AM
John's Avatar
New User
well, if your EGR and distributer are kinda fouled up, i'd get them fixed before you retake the emissions test. i say this for one reason: in many states, you are only allowed to fail the test once. if you fail it a second time, i do believe your vehicle is not allowed to be driven until the problem (whatever it may be) is rectified. at least, i do believe that's how they do it here in Northern VA... then again, they're pretty harsh here...
Old Oct 4, 2001 | 11:50 AM
JunkeeCrx's Avatar
New User
yeah you can fail it twice here and be fine i think. just that after the second failure you have to pay the test fee again. BOOO
Old Oct 7, 2001 | 10:56 AM
fixhondas's Avatar
Excessive NOX is from excessive combustion temperatures, running lean, or advanced timing. Anything that controls mixture can be the culprit.
emooheo
May 18, 2008 02:55 PM
eg6sir88
Feb 7, 2006 06:20 PM
Count Blah
Feb 15, 2002 04:37 AM
