Koni yellow install help?
Old Oct 9, 2001 | 05:29 PM
Disco Monkey's Avatar
Default Koni yellow install help?
hello i will be recieving my koni yellows soon and i was wondering if anyone has any helpful hints or knows a page that has installation instructions. thanks for the help.
Old Oct 10, 2001 | 01:59 PM
martini's Avatar
Default Re: Koni yellow install help? (Disco Monkey)
I have a tip. Don't remove the spring compressor after you take the spring off the stock shock. I did this for some reason when doing a strut replacement. It took me forever to recompress that spring.
Other than that, no, It's really quite easy actually.
When putting the assembly back on the rears, you may need to use a floorjack to push up on the lower control arm. I've had to do that on a couple occasions.
Old Oct 10, 2001 | 03:12 PM
Stephen's Avatar
Default Re: Koni yellow install help? (martini)
If you have an Integra, you'll need a drill to make the hole in the stock dust covers a little bigger. The shaft of the Koni damper is a few mm greater than that of the stockers. There shouldn't be any other issues really.
Old Oct 10, 2001 | 07:46 PM
MysteryWagon's Avatar
Default Re: Koni yellow install help? (Stephen)
cars come apart the way they look, (quote by a friend). It is real easy, just take it apart and put it back together. it should not take long.
have fun
Old Oct 11, 2001 | 07:35 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Koni yellow install help? (ShaggenWaggon)
Yep, not too dofficult. The only thing you gotta watch out for are tight *** bolts. That's what made me take such a long time.
Get a buddy to help you too. For example, he can hold one part, while you try and shove a bolt back in or something.
dwillms
Suspension & Brakes
Jun 3, 2008 03:03 PM
b18LS
Suspension & Brakes
Nov 6, 2006 05:17 PM
GSR2NR
Apr 25, 2002 12:54 PM
reVVin
Mar 19, 2002 05:51 PM
Integra_Boi
Mar 15, 2002 09:14 PM
