should i get a new motor?
Old Oct 4, 2001 | 05:32 PM
nkSi's Avatar
New User
Default should i get a new motor?
I've got about 196k on my car now. Should i just get a swap with less miles or is it worth trying to work on the engine i have now...like do some piston work etc?
I'm also considering in putting a turbo in my car in the near future.
Old Oct 4, 2001 | 06:07 PM
DragII's Avatar
25 Year Member
Default Re: should i get a new motor? (nkSi)
just buy a new shortblock...should run you around 250 dollars or less
Old Oct 5, 2001 | 11:14 AM
976's Avatar
976
New User
Default Re: should i get a new motor? (DragIIcivic)
Agreed. Unless your head is in bad condition, just buy a new short block. Since you can keep running your engine right now, and if you know how to install pistons, rods, and rings. I would buy new JE pistons and forget about a turbo. Your compression will be high = HORSEPOWER. This is what I plan on doing sometime...
Old Oct 5, 2001 | 11:25 AM
rainforest's Avatar
Default Re: should i get a new motor? (B21A)
get the motor rebuilt just new seals, and bearigs all around, check your oil and water pump. Then if everything checks out work that bitch.
acura_b18c1
Apr 18, 2011 01:42 PM
T3T4B18
Apr 20, 2010 06:02 AM
dropped like its hot
Nov 17, 2005 05:33 PM
BlackGSR
Jun 23, 2002 05:23 PM
