Saturated or Peak & Hold
Old Oct 4, 2001 | 01:27 PM
DelsolVtec18's Avatar
New User
Default Saturated or Peak & Hold
Are 93-96 h23A non-vtec injectors Saturated or Peak & Hold injectors Are 96 B18C Vtec injectors Saturated or Peak & Hold injectors What will happen if I use Peak & Hold injectors in a car that is supposed to use Saturated injectors???What will happen if I use Saturated injectors in a car that is supposed to use Peak & Hold injectors???
Thanks for the info...
Old Oct 4, 2001 | 05:40 PM
bb6h22a's Avatar
Default Re: Saturated or Peak & Hold (DelsolVtec18)
All b-series injectors are saturated and flow at 240cc if I remember correctly, and you cannot use peak and hold injectors in a saturated car w/out the resistor pack for the peak and hold injectors, as the impedance's are different!
Old Oct 5, 2001 | 04:39 AM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: Saturated or Peak & Hold (bb6h22a)
sorry but you are wrong. Not all b series are saturated. The 88-91 first gen b16a's use peak and hold type injectors, and 92+ uses saturated(obd1 style plug or obd2 plug). And as for the prelude injectors i have heard that h22a 92-95 or 93-96(i havnt gotten to the bottom of this, but i would just get 93,94,or 95 yr injectors because they are for sure peak and hold) are peak and hold. They are 310cc by the way, now i beleive that if you have a P&H car you can remove the resistor box and run saturated injectors. And if you install a resistor box on 92+(saturated) car you should be able to run P&H. Please someone correct me if i am wrong.
later
manny
Old Oct 5, 2001 | 10:21 AM
New User
Default Re: Saturated or Peak & Hold (mannyman)
where is resister box located at...How does the resister box look like???
Old Oct 5, 2001 | 03:56 PM
bb6h22a's Avatar
Whoops sorry, forgot, not really a b-series kinda' guy. Anyway, the pre 97 h-series injectors are 310cc and peak and hold, the 97+ are 290cc and saturated. These numbers are from Dave P.
RACEPAK
Apr 29, 2010 01:41 AM
doodooheadfart
Feb 22, 2007 09:53 PM
