b16a engine problem
Old Oct 4, 2001 | 05:09 PM
89sir-9's Avatar
New User
Default b16a engine problem
i have an 89 civic si hatch with b16 a. while i was driving my car died on me. i tried starting it back up but all it does is crank. im getting spark and fuel. when it died it gave me no signs of anything going bad. i can hear the fuel pump when i turn the key. this is the first time ive had any problems since the swap. please send me some ideas if any. thanks
Old Oct 4, 2001 | 06:57 PM
rioninja's Avatar
Default Re: b16a engine problem (89sir-9)
good chance your timing belt went. pull the valve cover and take a look. If all that checks out, double check the fuel system. How do you know you are getting fuel? The fuel pump may indeed be pumping, but your injectors might not be firing. try a shot of starter fluid into the throttle body.
Keep us posted
Old Oct 5, 2001 | 06:27 AM
89sir-9's Avatar
New User
timing belt is on, fuel regulator gauge showing 40 psi
Old Oct 5, 2001 | 06:55 AM
SOHCArchangel's Avatar
check the wiring on all the injectors to the resistor, and the fuse relay, are you sure you are getting in-cylinder spark?
Old Oct 5, 2001 | 07:15 AM
VTEC4GS's Avatar
check the sensors that tell the ECU not to start the car, such as TPS, coolant, etc.
Greg
Old Oct 5, 2001 | 08:19 AM
89sir-9's Avatar
New User
i recently had ctr cams,skunk2gears, and vafc controller installed. a week later it happened
Old Oct 5, 2001 | 11:32 AM
rainforest's Avatar
check all your wireing to the ecu from the vafc. Thats my suggestion.
Old Oct 5, 2001 | 12:36 PM
89sir-9's Avatar
New User
double checked all the wiring from vafc to ecu and it looks fine, i tried cranking the car and it turned on for about 2 seconds then died. tried crankin it again and all it did was crank
Old Oct 5, 2001 | 08:51 PM
BreakStuff's Avatar
New User
Too much confusion here..
If this were sensor or ecu related then spark and or fuel injector pulse would not exsist...
You have to start from the basics and determine in the proper order..
Do you have spark at the cylinders? (not at the coil)
Do you have fuel injector pulse? (not fuel pressure)
without determining the above anything else is just a guess...
anterman
Honda Civic (2001 - 2005)
Apr 12, 2016 05:33 AM
Ryhaz
16
Mar 16, 2014 07:13 AM
H22TurboNos
Nov 5, 2007 03:16 AM
r3v da t3g
Oct 19, 2006 11:47 AM
turbocivic0618
Nov 24, 2005 08:20 AM
