PCV Valve
Old Oct 11, 2001 | 03:16 PM
brainwo's Avatar
New User
Default PCV Valve
I have LS/VTEC setup, B18b and p72 head (GSR). , Skunk2 intake maniflo.
Where shoud i plug the PCV valve? How?
Old Oct 11, 2001 | 05:43 PM
Spade's Avatar
Default Re: PCV Valve (brainwo)
Can't answer but, WHAT THE HELL IS THE PCV Valve? I ask and don't get an answer.
Old Oct 11, 2001 | 08:29 PM
Blown90hatcH's Avatar
Default Re: PCV Valve (Loco Honkey)
What about if you leave it open? Run a tube down to the ground?
Old Oct 12, 2001 | 02:35 AM
BSQ's Avatar
BSQ
Default Re: PCV Valve (Blown90hatcH)
You should run it to a oil catch can. The catch can will collect any oil which passes throught the PCV (postive crank ventilation) system. Go to http://www.geocities.com/bretq/DIY_O...tructions.html for further information on hooking up an oil catch can.
Old Oct 12, 2001 | 02:43 AM
Big James's Avatar
New User
Default Re: PCV Valve (BSQ)
I have seen V8's that run it to the exhuast. While it increases emmisions, it is said to increase performance. Any thoughts.
Old Oct 12, 2001 | 06:37 AM
Leo95SE's Avatar
Default Re: PCV Valve (Big James)
using exhaust pulses to pull out oil fumes.. decent idea.. sounds dirty tho.
so much for a nice shiney exhaust.
Old Oct 12, 2001 | 08:11 AM
Buzzbomb's Avatar
PCV stands for Positive Crankcase Ventilation. It's routes oil vapor from the crankcase into the intake where it is burned. It's just an emissions measure so raw oil vapor won't be circulated into the atmosphere.
You could just put a breather filter on the hose just after the valve so the crank can breathe.
Old Oct 13, 2001 | 07:37 AM
John's Avatar
New User
Default Re: PCV Valve (bluesiguy)
Remember to remove the PCV filter before your emissions test... they will fail you outright!
[Modified by DunReit, 4:37 PM 10/13/2001]
EKredpanda
May 13, 2015 06:36 AM
Set O' Nines
Oct 30, 2012 07:49 PM
SkoundrelUSA
Oct 15, 2006 02:29 PM
bennyhonda7
May 18, 2005 05:42 PM
JETSWU87
Mar 10, 2005 05:50 PM
