IS a lighter flywheel safe? Balance wise?
I've heard from several people that it is bad for your motor to run a lighter than stock flywheel. They said that all motors come balanced from the factory and running a lighter flywheel will throw the bottom end off balance and you can ruin bearings a lot faster.
Does anyone know about this?
sure, if the flywheel isn't balanced right. But if it is balanced correctly, it will wear no more than the stock flywheel.
mike93boost
Jul 3, 2006 08:42 PM
ProjectLudeSiR
Mar 15, 2004 03:21 AM
pentaq
Apr 29, 2003 04:36 AM
