Thread size for oil pressure sender
Old Oct 4, 2001 | 07:35 AM
92sleepR's Avatar
New User
Default Thread size for oil pressure sender
Does anyone know what the thread size on the oil pressure sender for a B18C is? i need to order some fitting and i don't have the manual handy.
Thanks!
Mike
Old Oct 4, 2001 | 12:17 PM
93LSivic's Avatar
Default Re: Thread size for oil pressure sender (92sleepR)
I believe 1/8 NPT
Old Oct 4, 2001 | 01:53 PM
dustin's Avatar
Default Re: Thread size for oil pressure sender (93LSivic)
1/8" NPT works but it is not actually the correct size. I forget what the correct size is I just used a 1/8" NPT fitting.
dustin
Old Oct 4, 2001 | 04:49 PM
highmilehatch's Avatar
Default Re: Thread size for oil pressure sender (dustin)
It is a metric size, not sure what exactly, however as stated above, 1/8 npt does work.
Old Oct 4, 2001 | 04:50 PM
bigTom's Avatar
Default Re: Thread size for oil pressure sender (turboeg)
just confirming (and adding another post to my count )
Old Oct 4, 2001 | 05:08 PM
bruthaboost's Avatar
The correct size is 1/8 bspt (British Standard Pipe Thread). Summit carries it for ten bucks. However Parker has the same part for 2.50. Swagelok also carries a bspt to npt nipple where you would need another fitting. You will have a difficult time fitting a npt into a bspt. The npt is a little larger and will not fit.
RedPinoySi
Jun 12, 2007 05:23 PM
DrivinVtec
May 29, 2006 05:49 PM
ITR3189
Jul 27, 2005 11:02 AM
redboost10
Feb 24, 2004 11:14 AM
