Takin Tint off the back window??
Old Oct 5, 2001 | 03:22 PM
Homer_Simpson's Avatar
Default Takin Tint off the back window??
Does anyone have experience doing this?? I have old tint on the back window on my integra... and i was wondering if anyone knew how to take it off without messing up anything?? let me know please thanks
Will~
Old Oct 5, 2001 | 03:39 PM
Dr Pooface's Avatar
Default Re: Takin Tint off the back window?? (*****rAcEr)
I've heard a heat gun works best.
Old Oct 5, 2001 | 04:07 PM
Default Re: Takin Tint off the back window?? (Dr Pooface)
cool...... anyone more suggestions out there??any thing helps....
Old Oct 5, 2001 | 07:21 PM
BreakStuff's Avatar
New User
Yes, a heat gun will remove the tint but leave a residue from the adhesive.. you might wanna try a tar/gum remover for that.. and be careful not to break the rear defroster grids, they break easily but can still be repaired if needed...
Old Oct 5, 2001 | 07:33 PM
Default Re: Takin Tint off the back window?? (BreakStuff)
alright...... ima try that toomrrow....... any more info would also be appreciated??? any other ways to do it w/o using a heat gun???? let me kno thanx in advanced
Old Oct 5, 2001 | 09:19 PM
Dusty's Avatar
New User
i used a dry cleaning tool. this is this best way. its an element that sprays steam you just sit there and warm up a spot pull away and warm up the next spot. comes off like buttah. I can do it for you in orlando for 20 bucks. adhesive is also loosened and wipe away. very clean just a little steam and water dripping.
i really dont know but you could try hair dryier maybe or maybe boiling some water....this is what i was gonna do but i found my steamer.....
Old Oct 5, 2001 | 09:43 PM
BreakStuff's Avatar
New User
Default Re: Takin Tint off the back window?? (Dusty)
Thats a good point Dusty.. The adhesive is meant to stick in "dry" heat conditions..
A steam iron also comes to mind and might be of some help..
Old Oct 5, 2001 | 09:59 PM
thanks guys..... ima try all the experiments out
Old Oct 6, 2001 | 05:43 PM
SlowEX's Avatar
New User
Try this out. http://www.tintdude.com/remove.html
Old Oct 6, 2001 | 10:44 PM
Default Re: Takin Tint off the back window?? (SlowEX)
i got the side tints off.......but the back i was too scare to attempt..... dont want to screw up anythng in my car so i'm bringing it to the shop to be done for 10 bux.... thanx guys for all the help
Old Oct 7, 2001 | 02:56 AM
Rain_man's Avatar
New User
Rear tint is a pain since you have the defroster lines. Have a shot do it unless you really want to do it yourself.
Old Oct 7, 2001 | 10:19 AM
WOTTEG's Avatar
My girlfriend and I removed the tint from her 89 Turbo Supra. It was a real pain. Took most of 6 hours throughout Saturday in the 100+ temps of Texas.
We tried the heat gun (One of those 400+ degree hobby guns) but the tint layers had already separated so that was no good to remove both layers.
We then soaked the remaining adhesive in ammonia with a plastic trash bag stuck to it to keep the ammonia from evaporating.
That worked wonders in some areas after doing it 3 times.
Other places it was still a mess.
So we pulled out the razor blades. We gave up on preserving the defroster and just scraped everything off the rear window.
At the top of the window where the factory gradation dots are, the tint adhesive would not come off though. Because the razors would not scrape between the dots.
Goof-Off worked great for finishing up the remaining adhesive on all the windows.
When we were all done the car looked great except for thatt area on top of the rear hatch window.
If you do one thing do this:
REMOVE THE TINT BEFORE IT TURNS PURPLE AND BEGINS TO BUBBLE!
after this point it will be trouble to get it off.
Good luck,
Me
Old Oct 7, 2001 | 10:28 AM
fixhondas's Avatar
Default Re: Takin Tint off the back window?? (WOTTEG)
a heat gun and lots of windex- windex breaks down the adhesive. We used to spray the windows down with water and put saran wrap on the inside and let it bake in the sun. This makes it easy to start on the edge- then as you pull it spray with windex and it will come off more- it is a slow process.
Old Oct 7, 2001 | 06:53 PM
Kazmans94cord's Avatar
uhh..i just found a corner where it started peeling off and i just took it right off in rows...and i have the defogger and radio lines on my back window..and mine is all good..nothin wrong with it
Old Oct 8, 2001 | 08:17 AM
WOTTEG's Avatar
Default Re: Takin Tint off the back window?? (fixhondas)
I think the active ingredient in windex is ammonia. Or it used to be.
You are right, a very slow process.
phoshyzzle
Nov 9, 2007 11:07 AM
darithS
Apr 26, 2006 09:04 PM
SlammedDC2teg
Mar 10, 2006 04:41 PM
streetracerof06
Nov 30, 2005 07:53 AM
KAYTHAN
Sep 11, 2004 08:30 AM
