Removing apper ball joint?
Old Oct 10, 2001 | 01:11 AM
brody's Avatar
New User
Default Removing upper ball joint?
I am installing a specialty products front camber kit and after allot of time and effort i finally budged the top plate of the ball joint out of the control arm, but ball joint is still connected and the lower bolt is still in the radius rod. I have a ball joint press, but it doesn't work very well (it's too damn big). I've gotten as far as i am using a small c-clamp and a flathead screwdriver to pry it out. How do I fully remove it to install the new ball joint?
(i posted this in the prelude fourm too, but thought this would be a better place. sorry for the cross-post)
[Modified by brody, 6:54 PM 10/10/2001]
Old Oct 10, 2001 | 01:15 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Removing upper ball joint? (brody)
Take the castle nut off, let the assembly hang, grab the biggest hammer you can find and.........
BANG THE **** OUT OF THE VERTICAL ARM!!!!!!!!!!!!!!!!!!!!
It'll come off, just get pissed at it.
russianswty
Feb 18, 2007 02:24 PM
rasinhell
Feb 3, 2005 01:47 PM
97hb
Mar 9, 2002 11:31 PM
KK
Jun 26, 2001 02:30 PM
