Jet reprogramming..
Old Oct 3, 2001 | 01:11 PM
ZUL8R's Avatar
Default Jet reprogramming..
Is this something that is worth doing on a civic with I/H/E?? who else can repragram an ECU besides Jet... Thanks
Old Oct 3, 2001 | 08:09 PM
Lei Siew Long's Avatar
Default Re: Jet reprogramming.. (shane89z24)
JET chips are junk. try XS engineering for a reprogrammed ecu.
Old Oct 3, 2001 | 08:41 PM
rainforest's Avatar
Default Re: Jet reprogramming.. (boostedeg6)
you dont need to upgrade your ecu if you are only running ieh so save your money the most hp you will get out of a ecu with your mods are 2hp maybe.
Old Oct 4, 2001 | 06:07 AM
ZUL8R's Avatar
Default Re: Jet reprogramming.. (rainforest)
What else can i do to get More power or tourqe without it costing me an arm and a leg...
Old Oct 4, 2001 | 06:11 AM
John's Avatar
New User
V-AFC unit is a must with an I/H/E... don't forget a cam gear(s)... I gained between 5 and 20 hp across my entire power band with the V-AFC and cam gear on a dyno...
Old Oct 4, 2001 | 06:16 AM
Spade's Avatar
Default Re: Jet reprogramming.. (DunReit)
And if you aren't Vtec, and want cheap horsepower....not cheap in the long run but hey....get some NOS.....and if you really want to only use the NOS when you are WOT get the switch that connects to the trottle body and it will only connect when you are WOT......nice little kick. I don't run NOS though, I feel that all the money I spend refilling the bottle will eventually cost more than a turbo.
standbackimapro
Jan 17, 2006 10:41 AM
98itr0448
Aug 24, 2004 08:01 PM
andreiscv
Apr 26, 2004 09:06 PM
TeamTooQuick
Apr 29, 2003 11:38 PM
itr501
Oct 11, 2001 08:24 PM
