Just intalled Apexi Dunk
Old Dec 22, 2002 | 07:57 PM
Hairy Gorilla's Avatar
Default Just intalled Apexi Dunk
Just as the topic says. Sorry, I don't have pics yet. I love the look, although it is a little big. My only complaint is that around 1-2k the exhaust rattles it I barely apply the throttle. Is this happening because the tip is just so big or what? Is the hanger loose? I'm sure this is common w/ any exhaust. Any help would be great.
Old Dec 23, 2002 | 06:00 AM
1bad-eg's Avatar
Default Re: Just intalled Apexi Dunk (TimmyMaryak)
Check and see if your exhaust is rubbing somewhere under your car.
Old Dec 23, 2002 | 06:06 AM
GreenR's Avatar
It's normal with the Dunk.
Old Dec 23, 2002 | 07:26 AM
Spade's Avatar
Check your heat shields. It is probably vibrating against one.
Old Dec 23, 2002 | 09:28 AM
MugenGTR's Avatar
Default Re: Just intalled Apexi Dunk (Spade)
how loud are those? i was thinkin about it but i heard they're frigging LOUD!
Old Dec 23, 2002 | 09:35 AM
Spade's Avatar
Default Re: Just intalled Apexi Dunk (MugenGTR)
It depends on how much they are bumping.
My heat shields only rattled a little....sounded like a loose bolt. Removed them and no more buzzing.
Old Dec 23, 2002 | 10:29 AM
b18cya's Avatar
i've got the same one...i've removed most of my heat shields & i've got no rattles.
doesnt the dunk sound badass!!!!
[Modified by b18cya, 11:29 AM 12/23/2002]
Old Dec 23, 2002 | 12:29 PM
Mrfirefox's Avatar
Default Re: Just intalled Apexi Dunk (b18cya)
Nice enjoy that dunk
Dunk
Any Apex exhaust
Old Dec 23, 2002 | 01:36 PM
b18cya's Avatar
Default Re: Just intalled Apexi Dunk (Mrfirefox)
Dunk
Any Apex exhaust
the n1 is too loud on a NA setup for my taste. but the dunk has the warmest, non buzzy sound i've ever heard. for Dunks
Old Dec 23, 2002 | 04:25 PM
Thanks, I think I found the problem. Unfortunately I am out of town now. I did a search last night and found it was probably a heat shield. when I shook the piping I noticed it hitting at part of the heat shield. It was and I bent it out of the way. I only let it idle, and it sounded normal. Thanks for the help.
BTW, the Dunk is freakin awesome. It is the only exhaust I have heard on a NA setup that is so deep. All I have right now is stock headers and cat, w/ the dunk bolted on, and it is great. I would highly reccommend getting one of these if you can find one anymore. I hope when I putmy test pipe on next week it won't change the sound much. If it does i'll take it off and get a high flow. Thanks again.
travanx
26
Feb 19, 2005 11:36 AM
invid
Jan 13, 2005 07:31 PM
skafia
Mar 24, 2003 03:37 PM
slopok7
Feb 24, 2003 09:59 AM
Hairy Gorilla
Dec 25, 2002 02:16 PM
