Building LS/Vtec For Boost
Old Dec 25, 2002 | 08:31 PM
The G2 Racer's Avatar
Default Building LS/Vtec For Boost
I'm going to build myself and LS/Vtec to run some boost on. I'd say about 14-16psi. But I'm not sure on how to build it. I want to use a B18C5 head and a b18b block. What do I need to do in order to reach my goals?
Old Dec 25, 2002 | 08:40 PM
sslude's Avatar
Default Re: Building LS/Vtec For Boost (The G2 Racer)
well, check your compression ratio first. you will want a low one. build up your bottom end with some pistons, piston rods, sleeves...ect.
Old Dec 25, 2002 | 09:26 PM
Pelican's Avatar
Default Re: Building LS/Vtec For Boost (sslude)
and if you haven't bought anything yet, go B20. And don't even worry about a VTEC head if you're gonna boost it. Crower makes breathe-easy cams that can substitute for the VTEC lobes so highly sought after.
B20Z and a T3/T4 with like .63 Turbine AR. <<-- Might be fun
Old Dec 26, 2002 | 09:27 AM
Default Re: Building LS/Vtec For Boost (Pelican)
Yes but B20 selvees aren't as strong as LS selvees. I could get a LS block reselveed to 84mm and still have it cost less then a b20. or am I wrong? Last thing I want to do is crack a cyl wall.
Old Dec 26, 2002 | 10:34 AM
porsche997dc2's Avatar
a ls sleeve block will cost a little more than a stock b20 block. Well, it's all depend on how cheap you get the block for.
Robs94gsr
Jan 12, 2010 05:04 PM
thegeezerkid
Jun 25, 2008 05:17 PM
wesley_925
Feb 22, 2008 05:57 AM
b18_racer805
Oct 13, 2005 10:48 AM
Ek9_6
Mar 6, 2003 11:39 AM
