braided clutch line
Old Dec 25, 2002 | 07:36 AM
integra6650's Avatar
Default braided clutch line
does anyone know where i can find these who sells them looking for goodridge preferably
Old Dec 26, 2002 | 08:11 PM
Default Re: braided clutch line (integra6650)
so i guess im gonna make my own??
Old Dec 26, 2002 | 10:36 PM
HOOKUPS-PRO-CRX's Avatar
if you are talking about the line between the clutch master cylinder and the slave cylinder on the trans.... then absolutely DO NOT change from the hard line to a steelbraided one. the steelbraided has way to much flex when under pressure and will not have enough pressure to maove the slave cylinder. (noe i know somebody is going to make a stupid comment about how there are steel braided brake lines....well remember brake lines are only about 14in. long not five feet like from the master cylinder to the slave cylinder.(trust me i have done it) you can however replace just the rubberline from the slave cylinder to the hard line it is only about 10in long. (ANY hose and fitting shop should be able to make you one.
Old Dec 27, 2002 | 02:17 AM
youngkow's Avatar
Default Re: braided clutch line (HOOKUPS-PRO-CRX)
You can use stainless line, and it works fine. Not as good as the stock hard lines, but they work. I did an auto to manual swap and all I could get my hands on were the SS line and fittings from summitracing.com . If you need the part #'s I could get them for you. But I would really suggest getting the factory hardlines. From what I measured, there is about 3/4" difference in the amount of pressing the clutch pedal in and where the contact point is for the clutch between the ss line and the hard line.
Old Dec 27, 2002 | 02:29 AM
Mista Bone's Avatar
D Tranny Guru
Slater and Todaracer @ Fastline performance can help.
I cannot find the link right now, but it is NOT the Subaru shop.
EDIT: found the link
http://www.fastlineperformance.com/clutchline.htm
[Modified by Mista Bone, 6:33 AM 12/27/2002]
Old Dec 27, 2002 | 03:53 AM
Default Re: braided clutch line (Mista Bone)
all i had in mind was the 10 inch rubber piece factory hardlines should always be good enough for me
Old Dec 27, 2002 | 08:16 AM
fastbrakes's Avatar
You can get the short line from the hard line to the slave cylinder for around $20 from Technafit..
Old Dec 27, 2002 | 11:31 AM
Default Re: braided clutch line (fastbrakes)
if i buy goodridge materials in bulk would anyone want a clutch line also
Old Dec 28, 2002 | 06:42 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
why would you want to do that when you can get a Fastline clutch line, professionally made for around 30 bucks? Personally I would not want to buy some leakey homemade line for the same price that I can buy one from a respected company that stands behind thier products.
later
matt
Old Dec 28, 2002 | 12:42 PM
Default Re: braided clutch line (champITR)
im a mechanical contractor i do this **** all day but its usually all stainless hard tube and swagelok fittings
Old Dec 28, 2002 | 01:35 PM
hybridb18's Avatar
yea, get one from fastline, i got one and it works reat,
Old Dec 30, 2002 | 04:41 AM
champITR's Avatar
Default Re: braided clutch line (hybridb18)
later
matt
Old Dec 30, 2002 | 02:18 PM
TODAwhore's Avatar
I'm sure you could go to a local rubber hose and gasket (local place here) company and they could make you one. Just take them the oem line so they know what fittings you need.
sohcturbo92vx
Feb 11, 2012 01:44 PM
92lxsleeper
Sep 25, 2011 02:38 PM
sideswiped
Jun 13, 2010 01:35 PM
