Transmission fluid?
Old Dec 21, 2002 | 09:36 AM
Brolli007's Avatar
Default Transmission fluid?
What tranny Fluid should I use for my 91 LS Teg and how much do I need. I can't find my owners manual. I dont think the car has had the tranny fluid changed in a long long time cuz I bought it with 105k miles and it needed a lot of work to get it into good working order. Should I feel a difference in tranny after fluid change and what would not changing fluid for a long time due to the trans? (Manual of course).
Sorry for long post. Thanks for help in advance.
Old Dec 21, 2002 | 10:55 AM
jdmillusion's Avatar
Default Re: Transmission fluid? (Brolli007)
most manuals i've seen requires an annual tranny fluid change. it uses the same method as an oil change. although i haven't seen tranny flush fluids before. you drain fluid. fill back up, with some good honda mtl. i've never used the 10w before. get some reaction from them as well. honda service shops use 10w30.
Old Dec 21, 2002 | 11:44 AM
Brolli007's Avatar
Default Re: Transmission fluid? (jdmillusion)
Thanks... go get that Trueno. Anyone else with Tranny fluid/Tranny advice?
Old Dec 21, 2002 | 11:52 AM
lightning's Avatar
Honda MTF, the only way to go.
Old Dec 21, 2002 | 01:01 PM
Kamin's Avatar
Default Re: Transmission fluid? (lightning)
honda MTF rules.
Old Dec 21, 2002 | 01:02 PM
R_yd's Avatar
Default Re: Transmission fluid? (Kamin)
honda mtf
Old Dec 21, 2002 | 01:04 PM
ninesecrx's Avatar
Honda mtf...
Old Dec 21, 2002 | 01:51 PM
ejprimo's Avatar
Default Re: Transmission fluid? (ninesecrx)
mtf by honda
Old Dec 21, 2002 | 04:29 PM
Lord Helmet's Avatar
Default Re: Transmission fluid? (ejprimo)
I say if you plan to driving agressively then redline mtl is the way to go. or if you just drive like: Driving Miss. Daisy then stick to honda mtf. I had the oem honda stuff but it's not so great when you want to rip thru the gears during the cold winter season since it gets to be pretty notchy and doesen't shift as good but the redline mtl cured the problem also overnight.
[Modified by sleeperciv, 5:33 PM 12/21/2002]
Old Dec 22, 2002 | 08:20 AM
Brolli007's Avatar
Default Re: Transmission fluid? (sleeperciv)
Thanks, I guess I will go with Honda mft but I still want to know if I should feel a significant difference when I change the fluid. What do you guys mean when you say shifts are notchy? I never had a manual acura b4 so I dont know what a good new tranny should feel like.
Old Dec 22, 2002 | 08:31 AM
Brolli007's Avatar
Also, why and how does changing fliud improve how smooth the Tanny shifs? What about old fluid makes it work poorly. (I'm looking for a technical answer just for my own knowlege). Thanks
Old Dec 22, 2002 | 11:13 AM
Kataku2K3's Avatar
Dirty oil causes the synchros to not synchronize the gears as good which can cause getting into gear to be a bit harder.. Over time the synchros do wear out so just changing your fluid may help but not cure the problem... Honda MTF also has friction additives over normal oil which make the synchros work correctly that's why you should use it over just normal oil.. There are many things that can go wrong tho... A bent "interlock" in the tranny can cause shifting to be a nightmare.. Bent forks can also do the same thing.... Try the tranny oil change and if you still notice it to be harder to get in gear than it should then consider a rebuild... Latez
Old Dec 22, 2002 | 12:09 PM
Brolli007's Avatar
Default Re: Transmission fluid? (JDMspecEG6)
Thanks, that was a very helpful explination. I'm not so worried about my tranny problem as much as I just want to understand it.
out of 5 for than answer.
purple98ek
Jun 6, 2007 06:18 PM
AlekSir
Mar 22, 2005 07:20 AM
DeDonDeRosa
Jul 27, 2002 07:38 AM
Money Hou$e
Apr 24, 2002 04:46 PM
onyx00
Oct 27, 2001 07:56 AM
