Tach and speedo dont work
Old Dec 25, 2002 | 04:44 PM
ls-t del sol's Avatar
Default Tach and speedo dont work
I have a 2000 ls swap in my 95 del sol. Im running a p06 ecu chipped to ls specs by erics racing, designed to have an 8K redline and no speed limiter. Motor runs perfectly, throws no codes, but the tach and speedo dont work. Everything is plugged in.
Can i bypass the ecu and run a wire from the rpm signal wire coming off the distributor stright to the tach? Can i do the same for the speedometer? If you have any suggestions, please post them. Thanks
Old Dec 25, 2002 | 06:23 PM
Redline130's Avatar
Default Re: Tach and speedo dont work (SolReaver)
Is your VSS plugged in? Or maybe it's broke.
Old Dec 25, 2002 | 06:34 PM
Jared's Avatar
Default Re: Tach and speedo dont work (cyber13)
check all your fuses.
evoluti0n12
10
Jul 30, 2009 01:53 PM
I8ayellowcrayon
Apr 1, 2008 05:51 AM
civic08
Feb 28, 2008 09:22 PM
b_serious
12
May 11, 2006 04:26 PM
OneThirtyEight
Jan 10, 2005 06:05 AM
