The LS/VTEC and B18C Alternative !! Has anyone done this ??
Old Dec 21, 2002 | 03:56 PM
Nix_TEG's Avatar
Default The LS/VTEC and B18C Alternative !! Has anyone read this ??
I Got this article from this site ,
http://www.hondastyle.com/news/wmview.php?ArtID=33
HAS any one done this ???????????????
by 2ndGenTeg
In my last article, I wrote about the evils of LS/VTEC- namely the rod stroke ratio and its subsequent limitations. Remember, power is nothing more than the product of torque and RPM. Hondas make power through high RPMs, not torque. LS/VTEC increses torque, but limits the redline. So how do you get the best of both worlds?
Consider this: Johnny Hondaman, looking at installing an LS/VTEC or B18C into his cherished ride. Here are his options:
B18C: 1797cc of displacement 1.58:1 r/s ratio 140-150 hp
LS/VTEC 1834cc of displacement 1.54:1 r/s ratio 155-165 hp(?) (I have yet to see a dyno of a "stock(?)" LS/VTEC- no cams, stock I/H/E, stock internals, etc.)
So what's a guy to do? I have a better idea.
The Alternatives
So now consider these-
For the same price tag as that B18C, you could do this: B16A1 (JDM Integra XSi) Cylinders bored and sleeved to 86 mm Forged rods and pistons, 12.5:1 cr
And have the following results: 1789cc of displacement 1.74:1 r/s ratio 150-160 hp
For the same price as an LS/VTEC, you could do this:
B16A1 Cylinders bored and sleeved to 86 mm Forged rods and pistons, 12.5:1 cr B17A crank
And have the following results: 1891cc of displacement 1.68:1 r/s ratio 180-190 hp
The most expensive part would be the B17A crank. New, I was quoted $977.23 from my local Acura dealer, and I have yet to see one used. However, since the B16A and B17A deck heights are identical, the rods would be shelved parts- no custom machining (cheaper!). Also, most piston manufacturers do make 86mm bore pistons, to any desired compression ratio.
It should also be noted that both of these options would employ the cable tranny found on the B16A1. If your car is already a cable tranny, no problem. However, if yours is a hydro, expect to invest a couple bones in a new tranny (CTR, maybe?).
The Advantages
So what has Johnny gained, really? Why go to the trouble of assembling an engine when you could just buy a B18C or slap a VTEC head on an LS block?
Advantages over both the B18C and LS/VTEC
-For the same price, you already have a built engine, including: forged rods and pistons, sleeved cylinders, and high compression pistons. Comparably built, a B18C or LS/VTEC would be much more expensive; first you would pay for the engine, then pay for the build-up.
-Oversquare engine geometry (bore>stroke). This is another one of those little things that will increase your redline and reduce stress on your engine internals (read: reliability). With the B16A crank, bore/stroke would be 86/77. With the B17A crank, bore/stroke would come to 86/81.4.
-Better rod/stroke ratios. Although you lose 8cc of displacement (so what?), the r/s ratio of the B18C alternative would improve from 1.58:1 to a near perfect 1.74:1. The increase in redline would more than make up for the loss in displacement. In the LS/VTEC alternative, it would improve dramatically from 1.54:1 to 1.68:1.
Additional advantages over LS/VTEC
-Uses a B17A VTEC crank. The VTEC cranks are far superior to their non-VTEC counter parts, and perform much better at high engine speeds. This is due to (among other things) better lubrication and better rod bearings (although these would more than likely be upgraded, regardless).
-Uses a B17A VTEC block. No more machining, tapping, and drilling the B18A/B block to accomodate VTEC. Much more user and installer friendly, much more reliable.
-1891cc of displacement. Remember how excited everyone was to get an extra 37cc of displacement for their VTEC motor? Well, this is an extra 94cc. Nearly three times the increase, and 57cc more than an LS/VTEC, with all the aforementioned advantages.
Between the superior engine components and geometry, and properly built (and with an adequate valvetrain), I can see this engine spinning to 12K RPM all day without a hitch. There aren't cams out there that could use 12K, but I'll bet you could. And that speaks volumes about the engine.
The Disadvantages
By now, everyone is pretty familiar with my favorite saying: If it was all that great, Honda would have done it in the first place.
-The combustion chambers in the head will have to be machined to accomodate an 86mm bore. While this isn't a huge problem or really especially costly, it does present another problem. It increases the size of the combustion chamber. Combine that with the B16A's or B17A's relatively short stroke, and getting a piston dome high enough to generate a respectable compression ratio starts to look pretty big. This creates two problems.
1: Valve to piston contact becomes an issue with any high dome piston used in conjunction with any high lift/ long duration camshaft. Survival here depends on a good valvetrain and knowing when to say when and not getting too aggressive when choosing a compression ratio. At 12.5:1, it should be safe, and pump gas would still be an option. Good tuning of the valve timing and an experienced engine builder will also help immensely.
2: A high dome piston isn't all it's cracked up to be. Sure, generally the higher you go with compression, the more power you can make. However, once the piston dome becomes too high, you start to run into combustion issues. Think of the combustion wave as it is first ignited in the chamber. With a smaller or flat dome piston, the combustion wave has a much easier, much more direct route across the piston and combustion chamber. The higher the piston dome gets, the more it is in the way of this combustion wave. For these two reasons, I wouldn't go above a 12.5:1 compression ratio with this engine. The piston dome would simply have to be too big to be practical.
-When I first started exploring the possibility of boring the cylinders, I talked to many people who had bored theirs out to 84mm. The first question I asked was why stop there? Why not keep going to 86? 90? Larger? The largest you can bore the stock cylinders is 84mm. Any larger than that, and the cylinder walls become too thin. So what about sleeving? When working with a larger bore application and sleeved cylinders, you can only go so far before from above, the cylinders begin to look like an Audi logo. The achilles heel of the engine has now become the head gasket, and the space between the cylinders. To remedy this, a thicker head gasket is necessary (further increasing our dome height problem), and strong head studs (such as the ARP) to reduce flex.
So What?
This motor has potential. In a serious build (aggressive cams, head work, bolt ons, etc...) and some good tuning, I can see this engine hitting 210-220 hp without too much difficulty. Couple that with its good geometry (less stress on your engine internals- reliability!), and this would far and away be my choice over an LS/VTEC. It does have its weak points, but I believe that with an experienced engine builder by your side, they shouldn't present a problem at all, and are nowhere near as big an obstacle as a bad rod ratio is. If I were starting from scratch, trying to decide what to build, this would be it. Cheaper price tag, better geometry, superior reliability, and more potential. So, Mr. Hondaman, what's it gonna be?
[Modified by Nix_TEG, 5:29 AM 12/22/2002]
Old Dec 21, 2002 | 06:50 PM
ill phil's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (Nix_TEG)
I'm sorry, but I'm not sure I agree on the cheaper price tag.....
B17 block......lets say you find one for 500
Sleeving...... to 86 mm from GE you're looking at what 700-800 or so
New Rods and pistons..... 700-800
Everything new i.e. bearings, pumps, gaskets..... say 300
Once again you're looking at over 2 grand. For what? a better rod/stroke ratio, not having to run $100 oil lines, some machine work, and a closer to square motor? I'm sorry but look at Jeff at IB's motors.... running bored 1.8 and 2.0 motors easily putting out the type of power you are talking about with no high RPM issues and generally not having to bore to 86mm. Shoot you could spend the extra $300 to $400 to start with and start with an already VTEC GSR or type R platform, sleeve that to 85mm and have a 2.0 that only needs to rev to 8.5k to make its power.
I understand your points and yes they are very logical. But currently I am building an Ls/Vtec that will be using OEM parts, running around 12:1 c/r and still being ok to rev to 8k-9k, which will probably be higher than necessary to make my peak power..... and for how much? The way its looking now for under $1200-1400. With the right combo of cams and tuning , I should be able to push around 200 whp if not more. I'll reply again in a couple of weeks to let the final costs be known...
Plenty of thoughtful info in this article.... jsut figured I'd share my thoughts. See ya
-Brent
Old Dec 22, 2002 | 12:01 AM
RenoRacing's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (ill phil)
why is it that everyone thinks ls/vtec is so expensive, easily put my complete ls/vtec swap together into my dx hatch for 1500, tranny, new clutch, new axles, mounts, linkage, block, head, oil lines. and that price is being generous, probably more like 1200.
Old Dec 22, 2002 | 12:35 AM
Jackson's Avatar
Take your ls/vtec to a road course and rev it all day long and then come back here and tell us how it does. I had an ls/vtec before...so I am not talking out of my ***...I just dont think ls/vtec motors were meant to be tracked. It was a fun street/drag motor, but nothing else. I think the b16a block with b17 crank and rods bored to 84mm-86mm is an excellent idea. I have wanted to do that same set up for a while now just so I can rev the snot out of it at the track...
[Modified by Jackson, 9:35 AM 12/22/2002]
Old Dec 22, 2002 | 01:21 AM
ill phil's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (Jackson)
Jackson- I can definitely understand having a motor that can rev to heaven for a track person, but in this instance I took it as a drag motor since he's discussing the higher wheel hp and not power curve over an RPM range. I'm still disappointed that we don't have a real road track around here, hence me building an LS/vtec for drag use. Why didn't you like your Ls/vtec for the track? I can understand the high RPM usage, but isn't quite a bit of tq helpful for tracking days? You can lay it to me straight thats fine, I honestly don't know much about road racing or auto-x and would like to know more
Old Dec 22, 2002 | 12:15 PM
3rdGteg's Avatar
The above writeup is very interesting and would enjoy reading some more inputs on comparing the ls/vtec to that of the b16a1 sleeved/b17 crank motor. Any more pros and cons? I have a spare LS longblock and b16a longblock sitting around and also trying to decide what should be my next buildup.
Old Dec 22, 2002 | 06:12 PM
RenoRacing's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (3rdGteg)
i wasn't contesting the reliability of the GSR or Stroked b17/b16, but don't try to say that ls/vtec is the same price as over 1500$ in machine work. And i have rev'd my car all day long and driven it home. then about 2 weeks later i drove 1600 miles in one week to san diego and back. it's all in the quality of the work and the parts. ls/vtec is a very cost effective and powerproducing method, and it's as simple as that.
Old Dec 22, 2002 | 06:51 PM
havalilsi's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (HavokRacing)
what about a gsr block bored to 2 litres. i'm not sure of the cost, if you want more torque, bore it to 84.5mm then you shouldnt have any of the sealing problems i've heard about on the 85+mm bores plus you have room for error in the cyl wall
Old Dec 22, 2002 | 10:39 PM
riceboy's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (havalilsi)
blah blah blah, everyone knows about these setups, they have been done before, and yes they have their advantages.
but that dosent matter on the street
LS
T3/To4E @8 psi
BFG radials
that will make you happier. bottom line
[Modified by riceboy, 7:40 AM 12/23/2002]
Old Dec 23, 2002 | 02:50 AM
Norcalstoppy's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (riceboy)
wa wa wa.....
I read that article, very convincing and sound. I'm sure whatever he says is true, but in actuality there are tons of LSvtec and CRVtec motors out there that runs just fine revving to 8k rpm.
There was another argument about Rod/Stroke ratio vs Bore/Stroke ratio.
Search under my ID, it should come up.
jay kim
Old Dec 23, 2002 | 03:30 AM
Jeff C's Avatar
Looks like you have a shop though which means you have connections.
Old Dec 23, 2002 | 08:43 AM
icelarry27's Avatar
Default Re: The LS/VTEC and B18C Alternative !! Has anyone done this ?? (AllMotorMonster+)
i had an ls-vtec, and i revved up to 9k rpms all day long, no problem, mine was also fully built an i never lost while i had the engine, unfortunately, i had to sell it cuz i was runnin low on $$$ ....i raced M3's, vettes, stangs, all sorts of cars, and never lost, ls-vtec would be my choice any day of the week, but its pretty expensive, so im gonna have to go with a gsr engine net time around
virgstyle
Jul 5, 2006 08:48 AM
92B18Bvx
18
Apr 5, 2004 08:28 PM
V8killa1.8
Jun 1, 2003 05:51 PM
Nix_TEG
Dec 22, 2002 11:15 AM
cr00klyn718
17
May 12, 2002 01:19 PM
