b16a map sensor? help!
Old Dec 21, 2002 | 08:45 AM
dxlst's Avatar
Default b16a map sensor? help!
help! my brother is doing a jdm 91-93 b16a swap to his 88-91 civic ef..his map sensor is bad...
which sensor is compatible with the older b16a engine?.. will the sohc ex one works? will the 94-95 gsr one works?
thanks in advance for any info
Old Dec 21, 2002 | 08:55 AM
TEAMGENDAI's Avatar
Default Re: b16a map sensor? help! (dxlst)
Any map should work but if you can find one out of like 90 91 teg or 88 91 civic it would probably be easier for the vacum line to attatch but you can user the newer ones if you would like
velisma
Feb 6, 2009 06:08 AM
gsxr1k05
Jan 15, 2007 12:58 PM
runeminaEF9
Apr 30, 2006 05:36 PM
mongoliandonuts
Sep 25, 2004 04:42 PM
dxlst
Aug 27, 2002 07:44 PM
