help with check engine light
Old Dec 25, 2002 | 08:40 PM
showcarmike's Avatar
Default help with check engine light
Whats up everyone......just had a quick question.....i got stuck in the snow today and in order to get out of the snow I was spinnin the wheels out because of the snow.......now my car sounds funny(like a ticking noise) when i press the gas.....and the check engine light is on....what can the problem be....please help me out
thanks
Old Dec 25, 2002 | 10:09 PM
TEAMGENDAI's Avatar
Default Re: help with check engine light (showcarmike)
what year car??? and model??
Old Dec 25, 2002 | 11:47 PM
salbaje's Avatar
what code is it throwing
Old Dec 26, 2002 | 09:47 AM
Default Re: help with check engine light (TEAMGENDAI)
96 integra
Old Dec 26, 2002 | 10:00 AM
StageIIIhb98's Avatar
you need to pull the code to let us know how to answer your Q.
go to the pass. side and remove your kick panel.
you should see a two wire plug in a greenish rubber holding the plug
take a wire or paper clipe and jump both wires then turn the key to the on position and count the light's
longer light's are the first digit and the faster lights are the second digit.
you may have more than one code so keep counting untill it blinks the same amount again.
Blink Pass Blink Pass Blink Pass blink blink blink
this code will be 33 three long blinks and then three fast one's
stockton12
Jan 30, 2014 06:24 PM
lc42481
11
Feb 23, 2009 12:57 AM
DuVaL rAcEr
Jan 27, 2007 06:23 AM
si 1
Mar 31, 2006 12:35 PM
Navid OG
Jul 27, 2004 08:31 AM
