d16 question
Old Dec 20, 2002 | 07:11 PM
BluntMan's Avatar
Default d16 question
iy you have a d16 re-sleeved to a 2.0, what size pistons will you be running?
Old Dec 20, 2002 | 09:53 PM
BluntMan's Avatar
Default Re: d16 question (BluntMan)
come on! someone has to know. and also how big of a displacment can you go on a d16 with a stock crank?
Old Dec 20, 2002 | 11:31 PM
Mista Bone's Avatar
D Tranny Guru
with stock crank, you are limited to about 1780 cc's
Old Dec 22, 2002 | 12:43 PM
BluntMan's Avatar
Default Re: d16 question (Mista Bone)
whats the biggest mm sleve you can run without tweaking the block too much, and what would the cc's be on that with a stock crank?
Old Dec 23, 2002 | 03:46 AM
Mista Bone's Avatar
D Tranny Guru
78 mm bore is as big as you can go on a RACE motor = 1720 cc with stock stroke.
Old Dec 23, 2002 | 09:57 PM
BluntMan's Avatar
if i went to a 78mm bore, whats the biggest crank i could run without having to grind too much out of the block. i dont mind clearencing the block a little, but dont feel like grinding the s**t out of it either. and if i ran that size crank how many cc's would it be then?
Old Dec 24, 2002 | 02:13 AM
Mista Bone's Avatar
D Tranny Guru
you don't want a bigger crank. The RS ratio is already pretty crappy to begin with.
Old Dec 24, 2002 | 01:44 PM
BluntMan's Avatar
then whats your best suggestion for building a sohc?
Old Dec 24, 2002 | 09:22 PM
Mista Bone's Avatar
D Tranny Guru
D16A6 CRX motor with ZC pistons for the cheap route.
enriquez2000
Feb 11, 2012 07:12 PM
avaldez
Mar 16, 2010 07:53 PM
turboblack2door
Nov 18, 2008 08:42 AM
Swipe'd
Mar 3, 2007 06:17 AM
